MapperParsingException EventDate
Hi, i am getting the indexing failure attempts for graylog,
[497]: index [graylog_391], type [message], id [23bc82e8-7d97-11e7-99b8-2cd02dbeb2ea], message [MapperParsingException[failed to parse [EventDate]]; nested: IllegalArgumentException[Invalid format: “2017/08/10” is malformed at “/08/10”];]
[498]: index [graylog_391], type [message], id [23bca9f0-7d97-11e7-99b8-2cd02dbeb2ea], message [MapperParsingException[failed to parse [EventDate]]; nested: IllegalArgumentException[Invalid format: “2017/08/10” is malformed at “/08/10”];]
[499]: index [graylog_391], type [message], id [23bca9f1-7d97-11e7-99b8-2cd02dbeb2ea], message [MapperParsingException[failed to parse [EventDate]]; nested: IllegalArgumentException[Invalid format: “2017/08/10” is malformed at “/08/10”];]
I followed this custom mapping “http://docs.graylog.org/en/2.2/pages/configuration/elasticsearch.html#custom-index-mappings” and rotated the indice but still i see the logs rolling with those messages.
We are using graylog 2.2.3 with ElasticSearch 2.4.4
Can you please assist.
Thanks, Hema.
What’s the index template and index mapping you’ve created?
Hi Jochen, Its the same as mentioned in the docs. Here is the output from our server,
curl -X GET 'http://localhost:9200/graylog_deflector/_mapping?pretty'
  "graylog_392" : {
    "mappings" : {
      "message" : {
        "dynamic_templates" : [ {
          "internal_fields" : {
            "mapping" : {
              "index" : "not_analyzed",
              "type" : "string"
            "match" : "gl2_*"
          "store_generic" : {
            "mapping" : {
            "match" : "*"
        "properties" : {
          "PA_Risk" : {
            "type" : "string",
          "PA_Threat" : {
            "type" : "string",
          "ReceiveTime" : {
            "type" : "string",
          "SerialNumber" : {
            "type" : "string",
          "Subtype" : {
            "type" : "string",
          "Type" : {
            "type" : "string",
          "application_name" : {
            "type" : "string",
          "connection_id" : {
            "type" : "long"
          "connection_requests" : {
            "type" : "long"
          "facility" : {
            "type" : "string",
          "from_nginx" : {
            "type" : "string",
          "full_message" : {
            "type" : "string",
            "analyzer" : "standard"
          "gl2_remote_ip" : {
            "type" : "string",
          "gl2_remote_port" : {
            "type" : "string",
          "gl2_source_input" : {
            "type" : "string",
          "gl2_source_node" : {
            "type" : "string",
          "host" : {
            "type" : "string",
          "http_method" : {
            "type" : "string",
          "http_referer" : {
            "type" : "string",
          "http_response_code" : {
            "type" : "long"
          "http_user_agent" : {
            "type" : "string",
          "http_version" : {
            "type" : "string",
          "ingest_time" : {
            "type" : "date",
            "format" : "strict_date_time"
          "level" : {
            "type" : "long"
          "message" : {
            "type" : "string",
          "millis" : {
            "type" : "double"
          "nginx_access" : {
            "type" : "string",
          "nginx_error" : {
            "type" : "string",
          "process_id" : {
            "type" : "string",
          "remote_addr" : {
            "type" : "string",
          "remote_user" : {
            "type" : "string",
          "request_path" : {
            "type" : "string",
          "request_verb" : {
            "type" : "string",
          "response_bytes" : {
            "type" : "long"
          "response_status" : {
            "type" : "long"
          "server" : {
            "type" : "string",
          "source" : {
            "type" : "string",
            "analyzer" : "analyzer_keyword"
          "streams" : {
            "type" : "string",
          "timestamp" : {
            "type" : "date",
            "format" : "yyyy-MM-dd HH:mm:ss.SSS"
          "took_ms" : {
            "type" : "long"
I don’t see any mapping for the “EventDate” field in your mapping…
Hi Jochen,
This was the custom mapping i used, could you help me where i should add the EventDate field, please.
graylog-custom-mapping.json
  "template": "graylog_*",
  "mappings" : {
    "message" : {
      "properties" : {
        "http_method" : {
          "type" : "string",
          "type" : "long"
        "ingest_time" : {
          "type" : "date",
          "format": "strict_date_time"
        "took_ms" : {
          "type" : "long"
First, please format your text snippets properly. This will make them much easier to read: Markdown Reference
Example:
Text
There also is no mapping for “EventDate”.
Since the automatically discovered type of “EventDate” is not identical to what Graylog is trying to write into it, you have to define a proper mapping for it, just like you did for the other fields.
Hi Jochen,
I have not idea where to use the EventDate in CustomMapping, could you help format it for me, please?
Thanks, Hema.
Hi Jochen,
I have changed the Json as below and after executing, i could not find the custom mapping in the index
  "mappings" : {
    "message" : {
      "properties" : {
        "EventDate" : {
          "type" : "date",
          "format": "strict_date_optional_time"
curl -X GET 'http://localhost:9200/graylog_deflector/_mapping?pretty'                                 {
  "graylog_404" : {
    "mappings" : {
      "message" : {
            "mapping" : {
              "type" : "string"
            "match" : "gl2_*"
          "store_generic" : {
            "mapping" : {
            "match" : "*"
        "properties" : {
          "Location" : {
            "type" : "string",
          "PA_Risk" : {
            "type" : "string",
          "PA_Threat" : {
            "type" : "string",
          "ReceiveTime" : {
            "type" : "string",
          "SerialNumber" : {
            "type" : "string",
          "Subtype" : {
            "type" : "string",
          "Type" : {
            "type" : "string",
            "type" : "string",
          "connection_id" : {
            "type" : "long"
            "type" : "long"
          "device_product" : {
            "type" : "string",
          "device_vendor" : {
            "type" : "string",
          "device_version" : {
            "type" : "string",
          "dvc" : {
            "type" : "string",
          "event_class_id" : {
            "type" : "string",
          "facility" : {
            "type" : "string",
          "from_nginx" : {
            "type" : "string",
          "full_message" : {
            "type" : "string",
          "gl2_remote_ip" : {
            "type" : "string",
            "type" : "string",
            "type" : "string",
            "type" : "string",
          "http_method" : {
            "type" : "string",
          "http_referer" : {
            "type" : "string",
            "type" : "long"
            "type" : "string",
          "http_version" : {
            "type" : "string",
          "ingest_time" : {
            "type" : "date",
          "level" : {
            "type" : "long"
          "message" : {
            "type" : "string",
          "millis" : {
            "type" : "double"
          "msg" : {
            "type" : "string",
          "name" : {
            "type" : "string",
          "nginx_access" : {
            "type" : "string",
          "process_id" : {
            "type" : "string",
          "remote_addr" : {
            "type" : "string",
          "remote_user" : {
            "type" : "string",
          "request_path" : {
            "type" : "string",
          "request_verb" : {
            "type" : "string",
            "type" : "long"
            "type" : "long"
          "severity" : {
            "type" : "string",
          "severity_number" : {
            "type" : "long"
          "source" : {
            "type" : "string",
          "src" : {
            "type" : "string",
          "streams" : {
            "type" : "string",
          "suser" : {
            "type" : "string",
          "timestamp" : {
            "type" : "date",
          "took_ms" : {
            "type" : "long"
Can you please advise, if there is something wrong?
Thanks, Hema.
Hi Jochen,
Ignore my last message, i recycled the index and could see the template now, but the error still exist for the EventDate
2017-08-16T08:46:30.823-06:00 ERROR [Messages] Failed to index [60] messages. Please check the index error log in your web interface for the reason. Error: failure in bulk execution:
[65]: index [graylog_405], type [message], id [adaffc31-8291-11e7-99b8-2cd02dbeb2ea], message [MapperParsingException[failed to parse [EventDate]]; nested: IllegalArgumentException[Invalid format: "2017/08/16" is malformed at "/08/16"];]
[51]: index [graylog_405], type [message], id [adafae17-8291-11e7-99b8-2cd02dbeb2ea], message [MapperParsingException[failed to parse [generated_date]]; nested: IllegalArgumentException[Invalid format: "2017/08/16" is malformed at "/08/16"];]
"properties" : {
          "EventDate" : {
            "type" : "date",
            "format" : "strict_date_optional_time"
Can you advise please.
Thanks, Hema.
Your EventDate (and generated_date) field still has the wrong format or you’ve configured the wrong date format in the index mapping, depending which way you look at it.
Please refer to https://www.elastic.co/guide/en/elasticsearch/reference/5.5/mapping-date-format.html#built-in-date-formats for details about the built-in date formats.
