Graylog MapperParsingException
Hi all,
we have lots of index failures in our system:
MapperParsingException[failed to parse [02]]; nested: IllegalArgumentException[Invalid format: "2017/05/18 17:00:12" is malformed at "/05/18 17:00:12"];
how can i solve this issue?
It looks like that field used to be a number before.
You can create explicit schemas for your indices with an Elasticsearch index template: http://docs.graylog.org/en/2.2/pages/configuration/elasticsearch.html
Additionally, you should make sure that the field is always the same type, e. g. by using extractors/converters or the processing pipelines:
Found and solved. Thx
