Yet another mapper_parsing_exception
So I keep getting those indexing failures very often:
{"type":"mapper_parsing_exception","reason":"failed to parse [date-heure]","caused_by":{"type":"illegal_argument_exception","reason":"Invalid format: \"#Fields: date-time\""}}
The extractor for my Exchange 2016 logs is a CSV to field as:
date-heure,connector-id,session-id,sequence-number,local-endpoint,remote-endpoint,event,data,context
An actual corresponding (obfuscated) log line would be:
2018-11-14T15:04:27.478Z,MAIL-xx-M\Client Proxy MAIL-xx-M,08D63CBEF254F356,1,192.168.xx.xx:465,192.168.xx.xx:47907,>,“220 MAIL-xx-M.xxxx.ca Microsoft ESMTP MAIL Service ready at Wed, 14 Nov 2018 10:04:26 -0500”,
So what is failing here? How to investigate since I can’t view the message that actually failed?
Try:
https://www.elastic.co/guide/en/elasticsearch/reference/5.2/indices-get-field-mapping.html
something like (replace with the right address and index number
curl -XGET http://my.es.server:9200/graylog_XXX/_mapping/field/date-heure
… although: to me it seems your extractor tries to extract the header line, where obviously the word date-time is not in a proper date-format. You could try first dropping all lines starting with #, and only after that applying the extractor
Yes… good call! the log file headers are what’s causing issues here! Especially that the failures occurs every hour when the logs rotate.
I’ll adjust my regex and test! Thank you :slight_smile:
Yup, was headers breaking the parsing. Fixed by excluding lines starting with # symbol. Thanks mate!
