Lookup tables with multi value, pipelines and accessing data
Hello!
I’ve been trying to configure a simple pipeline rule to parse a JSONPath data table. The result of the lookup via the lookup test is the following:
  "single_value": "Mobile Safari",
  "multi_value": {
    "UserAgent": {
      "Family": "Mobile Safari",
      "Major": "5",
      "Minor": "1",
      "Patch": ""
    "Os": {
      "Family": "iOS",
      "Major": "5",
      "Minor": "1",
      "Patch": "1",
      "PatchMinor": ""
    "Device": {
      "Family": "iPad",
      "Brand": "Apple",
      "Model": "iPad"
  "ttl": 9223372036854776000,
  "empty": false
Using the pipeline rule debugger function though I’m only able to retrieve the single_value, not the multi_value:
debug(data); // Mobile Safari
debug(data.UserAgent.Family); // Passed value is NULL
What am I missing?
Thanks :slight_smile:
What’s the complete rule you’re using?
What’s the content of the data variable?
FWIW, you can either use a single value lookup (lookup_value()) or a multi value lookup ( lookup()) but not both in the same function call.
That was the issue :slight_smile:
Thanks, my bad :smile:
