Labelling and scaling of the y-axis
Hi
I have the problem that automatic scaling often generates a stupid value with many digits after the decimal point:
This makes reading difficult and if various graphs are displayed on top of each other, the time axis is also shifted.
Is there a way to format the label of the y-axis?
Is there also a way to fix the scaling, e.g. by setting the min and max value of the scale?
Thank you and BR
Jo
Hello && welcome @jocus
How did you setup this widget? also what version/s are you using?
Hello
We have a cluster with 3 nodes, each running Graylog 4.0.17+d0c5b22.
Setup of the widget:
BR
Jo
Hey @jocus
Sorry for the delay, I see you have custum fileds made for this widget.
Unfortunatly all there are “Row’s & Columns”. Not really for metrics, but this might change in the future versions.
