Kafka input without Zookeeper connection
I have been testing around to get an input to get data from Kafka. First i tried with the “old” version of the Kafka plugin which is version 0.9.x something. This did not work and only gave me the following logs:
2021-09-16T13:52:08.624+02:00 ERROR [KafkaTransport] WakeupException in poll. Kafka server is not responding.
2021-09-16T13:52:08.627+02:00 ERROR [KafkaTransport] Caught recoverable exception. Retrying
2021-09-16T13:52:08.666+02:00 ERROR [KafkaTransport] WakeupException in poll. Kafka server is not responding.
2021-09-16T13:52:08.666+02:00 ERROR [KafkaTransport] Caught recoverable exception. Retrying
2021-09-16T13:52:12.745+02:00 ERROR [KafkaTransport] WakeupException in poll. Kafka server is not responding.
2021-09-16T13:52:12.746+02:00 ERROR [KafkaTransport] Caught recoverable exception. Retrying
I then found somebody who updated this plugin to a newer version:
With this version you cannot skip the Zookeeper configuration, our zookeeper nodes cannot be accessed from where they are setup so I can’t get a connection to Zookeeper.
I wonder why you can’t disable the Zookeeper part in the new version of the plugin and if somebody has any input or solution to my problem?
Best regards,
Andreas
What version of Graylog are you running? IIRC we made improvements around Kafka versions in > 4.0, so this plugin shouldn’t be necessary.
We are using version 3.3.9, have read that it should be better in newer versions. Do you know if it is possible to use the Kafka plugin without using Zookeeper connection?
