Hi Team,
I’m already setup Graylog 3.1.4 on k8s in cloud. Till now, I’m using input ’ Raw/Plaintext Kafka’ which dependency with Zookeeper was works as expected. As you know, Kafka will release Zookeeper Dependency and maintain the meta data by it’s ownself. Did there have any plan using the brokers instand of Zookeeper or any plugin was supported in Graylog?
Levi
