Raw/Plaintext Kafka Input between Kafka and Graylog on dirrence server machine
Hi all,
Hope you’re doing well.
I have zookeeper running on server A and graylog server running on server B.
I create a raw/plaintext kafka input (Working if Zookeeper and Graylog on the same host, not working if split 2 server).
Is it possible to seperate Zookeeper and Graylog ?
Thanks !
If you can provide a bit more informations about your configuration it would make it possible for others to help you.
Thank @xtruthx,
I have 2 linux servers: 1 for Zookeeper + Kafka, 1 for Graylogs.
When i run Zookeeper + Kafka + Graylogs (create Raw/Plaintext Kafka input) on 1 server machine => That’s working (push message by producer and graylog will reviewed messgage ).
My goal want to seperate 1 server for Zookeeper + Kafka, my system will be use producer to push log messege to Kafka.
On config, i’ve set Zookeeper address = ip address (IP Address server Zookeeper + Kafka , Port 2181).=> Graylog didn’t received any message through Kafka
