JSON fields not extracted properly
Hi there, I have an issue with JSON fields not extracted properly.
First of all I have an JSON Extractor on my input that extracts the message field, this will result in a new MESSAGE field, with the following contents:
{"kind":"Event","apiVersion":"audit.k8s.io/v1","level":"Metadata","auditID":"e03a5c76-2122-4c1d-8265-be6e9cdc5e11","stage":"ResponseComplete","requestURI":"/api/v1/namespaces/ingress-nginx/configmaps/ingress-controller-leader-nginx","verb":"update","user":{"username":"system:serviceaccount:ingress-nginx:ingress-nginx","uid":"42491580-cda5-4856-9f1b-ae133faadba7","groups":["system:serviceaccounts","system:serviceaccounts:ingress-nginx","system:authenticated"]},"sourceIPs":["10.81.100.2"],"userAgent":"nginx-ingress-controller/v0.40.2 (linux/amd64) ingress-nginx/fc4ccc5eb0e41be2436a978b01477fc354f31643","objectRef":{"resource":"configmaps","namespace":"ingress-nginx","name":"ingress-controller-leader-nginx","uid":"7bd1f348-9586-45ea-b41c-897c8ba83985","apiVersion":"v1","resourceVersion":"178373"},"responseStatus":{"metadata":{},"code":200},"requestReceivedTimestamp":"2020-11-04T09:21:18.756400Z","stageTimestamp":"2020-11-04T09:21:18.759305Z","annotations":{"authentication.k8s.io/legacy-token":"system:serviceaccount:ingress-nginx:ingress-nginx","authorization.k8s.io/decision":"allow","authorization.k8s.io/reason":"RBAC: allowed by RoleBinding \"ingress-nginx/ingress-nginx\" of Role \"ingress-nginx\" to ServiceAccount \"ingress-nginx/ingress-nginx\""}}
All fields are then extracted with another JSON Extractor on the MESSAGE field. But then the issue is that the JSON path annotations is not extracted into fields. Is there any way to accomplish this?
Thanks!
he @christiaan
nested JSON is never easy to work with. You might want to work with the processing pipeline and what is the result of the extractor that has worked on the above mail.
