JSON Extractor stops messages from showing up in input
I have an Input that collects nginx access logs that are sent in the JSON format. I’ve been following the official Graylog guide on how to set up the extractor: How to use a JSON Extractor | Graylog
As it’s been suggested in the guide, I have two extractors: One to parse the message into a json field and one that extracts it.
Here’s an example message before parsing into a proper json field (data changed for privacy):
MyHost nginx: { “timestamp”: “1658474614.043”, “remote_addr”: “x.x.x.x.x”, “body_bytes_sent”: 229221, “request_time”: 0.005, “response_status”: 200, “request”: “GET /foo/bar/1999/09/sth.jpeg HTTP/2.0”, “request_method”: “GET”, “host”: “www…somesite.com”,“upstream_cache_status”: “”,“upstream_addr”: “x.x.x.x.x:xxx”,“http_x_forwarded_for”: “”,“http_referrer”: “https:////www.somesite.com/foo/bar/woo/boo/moo”, “http_user_agent”: “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/103.0.0.0 Safari/537.36”, “http_version”: “HTTP/2.0”, “nginx_access”: true }
And it is successfully extracted into a json field by a regex extractor: nginx:\s+(.*)
{ “timestamp”: “1658474614.043”, “remote_addr”: “x.x.x.x.x”, “body_bytes_sent”: 229221, “request_time”: 0.005, “response_status”: 200, “request”: “GET /foo/bar/1999/09/sth.jpeg HTTP/2.0”, “request_method”: “GET”, “host”: “www…somesite.com”,“upstream_cache_status”: “”,“upstream_addr”: “x.x.x.x.x:xxx”,“http_x_forwarded_for”: “”,“http_referrer”: “https://www.somesite.com/foo/bar/woo/boo/moo”, “http_user_agent”: “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/103.0.0.0 Safari/537.36”, “http_version”: “HTTP/2.0”, “nginx_access”: true }
After that it goes to the second extractor that fails completely. Not only is the preview incorrect (it omits some fields entirely):
remote_addr
x.x.x.x
request
GET /sth.dat HTTP/1.1
response_status
301
upstream_addr
body_bytes_sent
162
http_version
HTTP/1.1
request_method
GET
nginx_access
http_user_agent
request_time
0
host
sth
http_referrer
timestamp
1658475023.035
It also keeps missing, it doesn’t extract at all:
obraz
The second Extractor configuration is left default with the exception of “flatten structure” option being turned on.
I kindly request your help and wish you a good day!
I have come to the conclusion that the extractor works properly, however it still keeps missing. I do not know why this happens
Update: As soon as I apply the second extractor, the messages stop coming in.
Hello && Welcome @cesq
We would need to see the configuration made, How your ingesting them, logs (i.e., GL , ES) etc…
Its had to tell what the issue is from the information given.
When you do post any configuration please use the markdown, if you’re unsure take a look here
Hi, sadly I don’t understand what you mean by that. Nor do I understand these terms. Configuration of what exactly would you like to see?
Graylog version is 4.2.10+37fbc90 and it’s running on Red Hat - kernel 4.18
@gsmith I found an error log
It has something to do with the DateTime format
Error shown above, Elasticsearch failed to parse the date in the “DateTime” field. You need to convert it and best option probably would be a pipeline
Solution on this post: Failed to index [1] messages. failed to parse field [DateTime] of type [date] in document - #6 by cesq
