Hi All
Can we set Alert on gl data node’s backlog i.e if backlog exceeds 1 lakh on any node it will prompt alert.
Graylog version - 2.4.6
Elasticsearch version - 5.6
Hi All
He @Tafsir_Alam
you would need to check the Graylog API with your Monitoring System to alert if Graylog uses the journal. Graylog itself does not provide this function.
If you feel that this is a missing feature, please open a feature request: https://github.com/Graylog2/graylog2-server/issues
