Graylog 3.1.4 Alert Backlog Issue
Hi, I’m starting to notice something strange with the backlog option in Email Notification.
Basically, I have set the following:
Event: Search query in a stream every 5 minutes and within the last 5 minutes without using aggregation of results and custom fields.
Notification Setting: Message Backlog Ticked and set to 50.
Notification: Email Notification using the default Body Template:
— [Event Definition] ---------------------------
Title: {event_definition_title} Description: {event_definition_description}
Type: {event_definition_type} --- [Event] -------------------------------------- Timestamp: {event.timestamp}
Message: {event.message} Source: {event.source}
Key: {event.key} Priority: {event.priority}
Alert: {event.alert} Timestamp Processing: {event.timestamp}
Timerange Start: {event.timerange_start} Timerange End: {event.timerange_end}
Fields:
{foreach event.fields field} {field.key}: {field.value} {end}
{if backlog} --- [Backlog] ------------------------------------ Last messages accounting for this alert: {foreach backlog message}
{message} {end}
${end}
Issue:
When the query is triggered it is finding x5 logs within the 5 minute range and sending x5 Notification Emails each having x1 log message at the backlog section.
Questions:
Isn’t it supposed to send x1 Notification Email with x5 log messages at the backlog section?
Does Backlog option append any other logs after the trigger or only the matched logs?
Thanks,
Ryan
Somehow Solved.
When I configured the Event Alert with “Filter has Results”, it will send an email notification for every message it is matched with the query. Each Mail will contain only 1 backlog message and ignore the number of backlog message config.
When I configured the Event Alert with “Aggregation of Results reaches Thresholds” and set when count > 0, it will send only 1 email notification with all the messages matched with the query as backlog messages by following the backlog message config.
Ryan.
