Hi
Is there a way to set a notification from the web-console or server-side that will notify us whenever any Graylog nodes get backlogged?
Hi
such is not possible at the moment. It will be a feature request to make this possible.
You can still create script that will query node information from REST API and send mail if there is a problem.
First get nodes:
http://graylog:9000/api/cluster
And after their statistics:
http://graylog:9000/api/cluster/NODE_ID/journal
Or better NMS system like Zabbix to query statistics and send alert it problem. If you use Zabbix you can use this template:
@shoothub But how REST API will monitor graylog backlogged node? REST API will only show the cluster-info.
Maybe I don’t understand correctly your question. Do you want to check number of unprocessed messages in node or something different?
If yes, REST API ( api/cluster/NODE_ID/journal
) can return value:
"uncommitted_journal_entries":,
