Intermittent failure to load the WebUI after upgrade
This issue has had me pondering for a while now, because I can’t figure out how it happens intermittently but not in a regular way. It just happens at random.
While the server’s activities seem untouched, I have problems predicting whether the UI will be working or not when I connect.
The Issue
After upgrading graylog-server from the version 4.0.5 to the version 4.2.1 (same issue with the version 4.2.0) I found out that upon restarting the server it worked seamlessly, but for a certain period of time, then the WebUI becomes inaccessible and a blank page presents itself instead.
The blank page contains all the scripts, but no other <body> components:
Unfortunately this status remains for hours.
When the WebUI works as intended, no errors are thrown from the browser console. When it shows the blank page it throws a bunch of javascript errors for every installed plugin:
javascript errors on console
collapsed errors
I really can’t figure the source of this issue out, because, as I said, sometimes it works, sometimes it doesn’t.
Environmental information
server.conf
is_master = true
password_secret = <private>
root_username = admin
root_password_sha2 = <private>
root_timezone = Europe/Rome
http_bind_address = 192.168.37.45:9000
http_publish_uri = http://192.168.37.45:9000/
http_enable_cors = true
http_enable_gzip = true
http_max_header_size = 8192
http_thread_pool_size = 16
trusted_proxies = 127.0.0.1/32, 0:0:0:0:0:0:0:1/128
rotation_strategy = count
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
allow_highlighting = false
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
enabled_tls_protocols= TLSv1.1,TLSv1.2,TLSv1.3
auditlog_log4j_enabled = true
auditlog_log4j_logger_name = graylog-auditlog
server.log (from the last reboot)
2021-11-15T01:04:34.539+01:00 INFO  [ImmutableFeatureFlagsCollector] Following feature flags are used: {}
2021-11-15T01:04:41.704+01:00 INFO  [CmdLineTool] Loaded plugin: TelegramNotification 2.3.6 [de.irgendwr.TelegramNotificationPlugin]
2021-11-15T01:04:41.709+01:00 INFO  [CmdLineTool] Loaded plugin: AWS plugins 4.2.1 [org.graylog.aws.AWSPlugin]
2021-11-15T01:04:41.714+01:00 INFO  [CmdLineTool] Loaded plugin: Enterprise Integrations 4.2.1 [org.graylog.enterprise.integrations.EnterpriseIntegrationsPlugin]
2021-11-15T01:04:41.723+01:00 INFO  [CmdLineTool] Loaded plugin: Integrations 4.2.1 [org.graylog.integrations.IntegrationsPlugin]
2021-11-15T01:04:41.728+01:00 INFO  [CmdLineTool] Loaded plugin: Collector 4.2.1 [org.graylog.plugins.collector.CollectorPlugin]
2021-11-15T01:04:41.732+01:00 INFO  [CmdLineTool] Loaded plugin: Graylog Enterprise 4.2.1 [org.graylog.plugins.enterprise.EnterprisePlugin]
2021-11-15T01:04:41.737+01:00 INFO  [CmdLineTool] Loaded plugin: Graylog Enterprise (ES6 Support) 4.2.1 [org.graylog.plugins.enterprise.org.graylog.plugins.enterprise.es6.EnterpriseES6Plugin]
2021-11-15T01:04:41.741+01:00 INFO  [CmdLineTool] Loaded plugin: Graylog Enterprise (ES7 Support) 4.2.1 [org.graylog.plugins.enterprise.org.graylog.plugins.enterprise.es7.EnterpriseES7Plugin]
2021-11-15T01:04:41.746+01:00 INFO  [CmdLineTool] Loaded plugin: Threat Intelligence Plugin 4.2.1 [org.graylog.plugins.threatintel.ThreatIntelPlugin]
2021-11-15T01:04:41.755+01:00 INFO  [CmdLineTool] Loaded plugin: Elasticsearch 6 Support 4.2.1+5442e44 [org.graylog.storage.elasticsearch6.Elasticsearch6Plugin]
2021-11-15T01:04:41.761+01:00 INFO  [CmdLineTool] Loaded plugin: Elasticsearch 7 Support 4.2.1+5442e44 [org.graylog.storage.elasticsearch7.Elasticsearch7Plugin]
2021-11-15T01:04:42.211+01:00 INFO  [CmdLineTool] Running with JVM arguments: -Xms1g -Xmx1g -XX:NewRatio=1 -XX:+ResizeTLAB -XX:-OmitStackTraceInFastThrow -Djdk.tls.acknowledgeCloseNotify=true -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUnloadingEnabled -Dlog4j.configurationFile=file:///etc/graylog/server/log4j2.xml -Djava.library.path=/usr/share/graylog-server/lib/sigar -Dgraylog2.installation_source=deb
2021-11-15T01:04:43.434+01:00 INFO  [Version] HV000001: Hibernate Validator null
2021-11-15T01:05:13.163+01:00 INFO  [InputBufferImpl] Message journal is enabled.
2021-11-15T01:05:13.276+01:00 INFO  [NodeId] Node ID: 2f4965ee-d80f-4b81-beca-4aa4bb66bb37
2021-11-15T01:05:15.140+01:00 INFO  [LogManager] Loading logs.
2021-11-15T01:05:15.327+01:00 WARN  [Log] Found a corrupted index file, /var/lib/graylog-server/journal/messagejournal-0/00000000000207983642.index, deleting and rebuilding index...
2021-11-15T01:05:17.336+01:00 INFO  [LogManager] Logs loading complete.
2021-11-15T01:05:17.349+01:00 INFO  [LocalKafkaJournal] Initialized Kafka based journal at /var/lib/graylog-server/journal
2021-11-15T01:05:17.572+01:00 INFO  [cluster] Cluster created with settings {hosts=[localhost:27017], mode=SINGLE, requiredClusterType=UNKNOWN, serverSelectionTimeout='30000 ms', maxWaitQueueSize=5000}
2021-11-15T01:05:17.834+01:00 INFO  [cluster] Cluster description not yet available. Waiting for 30000 ms before timing out
2021-11-15T01:05:17.972+01:00 INFO  [connection] Opened connection [connectionId{localValue:1, serverValue:1}] to localhost:27017
2021-11-15T01:05:17.998+01:00 INFO  [cluster] Monitor thread successfully connected to server with description ServerDescription{address=localhost:27017, type=STANDALONE, state=CONNECTED, ok=true, version=ServerVersion{versionList=[4, 2, 17]}, minWireVersion=0, maxWireVersion=8, maxDocumentSize=16777216, logicalSessionTimeoutMinutes=30, roundTripTimeNanos=16926797}
2021-11-15T01:05:18.104+01:00 INFO  [connection] Opened connection [connectionId{localValue:2, serverValue:2}] to localhost:27017
2021-11-15T01:05:19.405+01:00 INFO  [InputBufferImpl] Initialized InputBufferImpl with ring size <65536> and wait strategy <BlockingWaitStrategy>, running 2 parallel message handlers.
2021-11-15T01:05:20.548+01:00 ERROR [VersionProbe] Unable to retrieve version from Elasticsearch node: Failed to connect to /127.0.0.1:9200. - Connection refused (Connection refused).
2021-11-15T01:05:25.561+01:00 ERROR [VersionProbe] Unable to retrieve version from Elasticsearch node: Failed to connect to /127.0.0.1:9200. - Connection refused (Connection refused).
2021-11-15T01:05:30.568+01:00 ERROR [VersionProbe] Unable to retrieve version from Elasticsearch node: Failed to connect to /127.0.0.1:9200. - Connection refused (Connection refused).
2021-11-15T01:05:35.573+01:00 ERROR [VersionProbe] Unable to retrieve version from Elasticsearch node: Failed to connect to /127.0.0.1:9200. - Connection refused (Connection refused).
2021-11-15T01:05:40.579+01:00 ERROR [VersionProbe] Unable to retrieve version from Elasticsearch node: Failed to connect to /127.0.0.1:9200. - Connection refused (Connection refused).
2021-11-15T01:05:46.342+01:00 INFO  [ElasticsearchVersionProvider] Elasticsearch cluster is running v7.10.2
2021-11-15T01:05:52.273+01:00 INFO  [connection] Opened connection [connectionId{localValue:3, serverValue:3}] to localhost:27017
2021-11-15T01:05:55.392+01:00 INFO  [ProcessBuffer] Initialized ProcessBuffer with ring size <65536> and wait strategy <BlockingWaitStrategy>.
2021-11-15T01:05:59.323+01:00 WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2021-11-15T01:05:59.424+01:00 INFO  [OutputBuffer] Initialized OutputBuffer with ring size <65536> and wait strategy <BlockingWaitStrategy>.
2021-11-15T01:06:00.316+01:00 WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2021-11-15T01:06:00.990+01:00 WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2021-11-15T01:06:01.528+01:00 WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2021-11-15T01:06:01.921+01:00 WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2021-11-15T01:06:07.179+01:00 INFO  [graylog-auditlog] urn:graylog:node:2f4965ee-d80f-4b81-beca-4aa4bb66bb37 node startup on 2f4965ee-d80f-4b81-beca-4aa4bb66bb37 initiated - Graylog v4.2.1+5442e44
2021-11-15T01:06:07.296+01:00 INFO  [ServerBootstrap] Graylog server 4.2.1+5442e44 starting up
2021-11-15T01:06:07.297+01:00 INFO  [ServerBootstrap] JRE: Debian 11.0.12 on Linux 4.19.0-18-amd64
2021-11-15T01:06:07.298+01:00 INFO  [ServerBootstrap] Deployment: deb
2021-11-15T01:06:07.299+01:00 INFO  [ServerBootstrap] OS: Debian GNU/Linux 10 (buster) (debian)
2021-11-15T01:06:07.300+01:00 INFO  [ServerBootstrap] Arch: amd64
2021-11-15T01:06:07.547+01:00 INFO  [PeriodicalsService] Starting 37 periodicals ...
2021-11-15T01:06:07.549+01:00 INFO  [Periodicals] Starting [org.graylog2.periodical.ThroughputCalculator] periodical in [0s], polling every [1s].
2021-11-15T01:06:07.637+01:00 INFO  [Periodicals] Starting [org.graylog.plugins.pipelineprocessor.periodical.LegacyDefaultStreamMigration] periodical, running forever.
2021-11-15T01:06:07.676+01:00 INFO  [PeriodicalsService] Not starting [org.graylog2.periodical.AlertScannerThread] periodical. Not configured to run on this node.
2021-11-15T01:06:07.678+01:00 INFO  [Periodicals] Starting [org.graylog2.periodical.BatchedElasticSearchOutputFlushThread] periodical in [0s], polling every [1s].
2021-11-15T01:06:07.680+01:00 INFO  [Periodicals] Starting [org.graylog2.periodical.ClusterHealthCheckThread] periodical in [120s], polling every [20s].
2021-11-15T01:06:07.724+01:00 INFO  [PeriodicalsService] Not starting [org.graylog2.periodical.ContentPackLoaderPeriodical] periodical. Not configured to run on this node.
2021-11-15T01:06:07.725+01:00 INFO  [Periodicals] Starting [org.graylog2.periodical.GarbageCollectionWarningThread] periodical, running forever.
2021-11-15T01:06:07.729+01:00 INFO  [Periodicals] Starting [org.graylog2.periodical.IndexerClusterCheckerThread] periodical in [0s], polling every [30s].
2021-11-15T01:06:07.757+01:00 INFO  [Periodicals] Starting [org.graylog2.periodical.IndexRetentionThread] periodical in [0s], polling every [300s].
2021-11-15T01:06:07.782+01:00 INFO  [Periodicals] Starting [org.graylog2.periodical.IndexRotationThread] periodical in [0s], polling every [10s].
2021-11-15T01:06:07.788+01:00 INFO  [LegacyDefaultStreamMigration] Legacy default stream has no connections, no migration needed.
2021-11-15T01:06:07.843+01:00 INFO  [Periodicals] Starting [org.graylog2.periodical.NodePingThread] periodical in [0s], polling every [1s].
2021-11-15T01:06:07.845+01:00 INFO  [Periodicals] Starting [org.graylog2.periodical.VersionCheckThread] periodical in [300s], polling every [1800s].
2021-11-15T01:06:07.863+01:00 INFO  [Periodicals] Starting [org.graylog2.periodical.ThrottleStateUpdaterThread] periodical in [1s], polling every [1s].
2021-11-15T01:06:07.870+01:00 INFO  [Periodicals] Starting [org.graylog2.events.ClusterEventPeriodical] periodical in [0s], polling every [1s].
2021-11-15T01:06:07.873+01:00 INFO  [Periodicals] Starting [org.graylog2.events.ClusterEventCleanupPeriodical] periodical in [0s], polling every [86400s].
2021-11-15T01:06:07.875+01:00 INFO  [Periodicals] Starting [org.graylog2.periodical.ClusterIdGeneratorPeriodical] periodical, running forever.
2021-11-15T01:06:07.880+01:00 INFO  [connection] Opened connection [connectionId{localValue:4, serverValue:4}] to localhost:27017
2021-11-15T01:06:07.895+01:00 INFO  [Periodicals] Starting [org.graylog2.periodical.IndexRangesMigrationPeriodical] periodical, running forever.
2021-11-15T01:06:07.911+01:00 INFO  [Periodicals] Starting [org.graylog2.periodical.IndexRangesCleanupPeriodical] periodical in [15s], polling every [3600s].
2021-11-15T01:06:07.958+01:00 INFO  [connection] Opened connection [connectionId{localValue:5, serverValue:5}] to localhost:27017
2021-11-15T01:06:08.030+01:00 INFO  [connection] Opened connection [connectionId{localValue:7, serverValue:7}] to localhost:27017
2021-11-15T01:06:08.051+01:00 INFO  [connection] Opened connection [connectionId{localValue:9, serverValue:9}] to localhost:27017
2021-11-15T01:06:08.020+01:00 INFO  [connection] Opened connection [connectionId{localValue:6, serverValue:6}] to localhost:27017
2021-11-15T01:06:08.083+01:00 INFO  [connection] Opened connection [connectionId{localValue:8, serverValue:8}] to localhost:27017
2021-11-15T01:06:08.279+01:00 INFO  [PeriodicalsService] Not starting [org.graylog2.periodical.UserPermissionMigrationPeriodical] periodical. Not configured to run on this node.
2021-11-15T01:06:08.280+01:00 INFO  [Periodicals] Starting [org.graylog2.periodical.ConfigurationManagementPeriodical] periodical, running forever.
2021-11-15T01:06:08.305+01:00 INFO  [Periodicals] Starting [org.graylog2.periodical.TrafficCounterCalculator] periodical in [0s], polling every [1s].
2021-11-15T01:06:08.307+01:00 INFO  [Periodicals] Starting [org.graylog2.indexer.fieldtypes.IndexFieldTypePollerPeriodical] periodical in [0s], polling every [3600s].
2021-11-15T01:06:08.308+01:00 INFO  [Periodicals] Starting [org.graylog.scheduler.periodicals.ScheduleTriggerCleanUp] periodical in [120s], polling every [86400s].
2021-11-15T01:06:08.309+01:00 INFO  [Periodicals] Starting [org.graylog2.periodical.ESVersionCheckPeriodical] periodical in [0s], polling every [30s].
2021-11-15T01:06:08.310+01:00 INFO  [Periodicals] Starting [org.graylog.plugins.sidecar.periodical.PurgeExpiredSidecarsThread] periodical in [0s], polling every [600s].
2021-11-15T01:06:08.310+01:00 INFO  [Periodicals] Starting [org.graylog.plugins.sidecar.periodical.PurgeExpiredConfigurationUploads] periodical in [0s], polling every [600s].
2021-11-15T01:06:08.366+01:00 INFO  [Periodicals] Starting [org.graylog.plugins.views.search.db.SearchesCleanUpJob] periodical in [3600s], polling every [28800s].
2021-11-15T01:06:08.477+01:00 INFO  [Periodicals] Starting [org.graylog.events.periodicals.EventNotificationStatusCleanUp] periodical in [120s], polling every [86400s].
2021-11-15T01:06:08.478+01:00 INFO  [Periodicals] Starting [org.graylog.plugins.collector.periodical.PurgeExpiredCollectorsThread] periodical in [0s], polling every [3600s].
2021-11-15T01:06:08.479+01:00 INFO  [Periodicals] Starting [org.graylog.plugins.forwarder.ForwarderStatePeriodical] periodical in [0s], polling every [15s].
2021-11-15T01:06:08.498+01:00 INFO  [Periodicals] Starting [org.graylog.plugins.license.LicenseManagerPeriodical] periodical in [0s], polling every [300s].
2021-11-15T01:06:08.538+01:00 INFO  [Periodicals] Starting [org.graylog.plugins.license.LicenseReportPeriodical] periodical in [300s], polling every [3600s].
2021-11-15T01:06:08.563+01:00 INFO  [Periodicals] Starting [org.graylog.plugins.license.StagedLicenseInstallerPeriodical] periodical, running forever.
2021-11-15T01:06:08.620+01:00 INFO  [Periodicals] Starting [org.graylog.plugins.auditlog.mongodb.MongoAuditLogPeriodical] periodical in [0s], polling every [3600s].
2021-11-15T01:06:08.667+01:00 INFO  [Periodicals] Starting [org.graylog.plugins.report.scheduler.ReportPeriodical] periodical in [120s], polling every [60s].
2021-11-15T01:06:08.673+01:00 INFO  [Periodicals] Starting [org.graylog.plugins.report.service.ChromeDriverCleanupPeriodical] periodical in [60s], polling every [180s].
2021-11-15T01:06:08.786+01:00 INFO  [LookupTableService] Data Adapter watchlist-mongo/61901db34d93d945cb9a70a0 [@5d635da0] STARTING
2021-11-15T01:06:08.789+01:00 INFO  [Periodicals] Starting [org.graylog.plugins.files.CleanupPeriodical] periodical in [0s], polling every [86400s].
2021-11-15T01:06:08.795+01:00 INFO  [LookupTableService] Data Adapter mac-ssid/602961387b867f0b9b165257 [@5ca767bd] STARTING
2021-11-15T01:06:08.796+01:00 INFO  [LookupTableService] Data Adapter network-aliases/5fc41b5adec571151748b6b4 [@4da9aba0] STARTING
2021-11-15T01:06:09.795+01:00 INFO  [LookupTableService] Data Adapter ssids/5fbaadc2588a9a48ea9db9b9 [@4a925457] STARTING
2021-11-15T01:06:09.798+01:00 INFO  [LookupTableService] Data Adapter interface-names/5fc421bddec571151748be22 [@13a39d43] STARTING
2021-11-15T01:06:09.803+01:00 INFO  [LookupTableService] Data Adapter subnets/5fbad765588a9a48ea9dea63 [@154175b3] STARTING
2021-11-15T01:06:09.813+01:00 INFO  [LookupTableService] Data Adapter mac-address/5fbab426588a9a48ea9dc2bd [@7816fbb9] STARTING
2021-11-15T01:06:09.846+01:00 INFO  [LookupTableService] Data Adapter watchlist-mongo/61901db34d93d945cb9a70a0 [@5d635da0] RUNNING
2021-11-15T01:06:09.878+01:00 INFO  [LookupTableService] Data Adapter ssids/5fbaadc2588a9a48ea9db9b9 [@4a925457] RUNNING
2021-11-15T01:06:09.880+01:00 INFO  [LookupDataAdapterRefreshService] Adding job for <ssids/5fbaadc2588a9a48ea9db9b9/@4a925457> [interval=60000ms]
2021-11-15T01:06:09.902+01:00 INFO  [LookupTableService] Data Adapter interface-names/5fc421bddec571151748be22 [@13a39d43] RUNNING
2021-11-15T01:06:09.904+01:00 INFO  [LookupTableService] Data Adapter mac-ssid/602961387b867f0b9b165257 [@5ca767bd] RUNNING
2021-11-15T01:06:09.930+01:00 INFO  [LookupDataAdapterRefreshService] Adding job for <mac-ssid/602961387b867f0b9b165257/@5ca767bd> [interval=60000ms]
2021-11-15T01:06:09.932+01:00 INFO  [LookupDataAdapterRefreshService] Adding job for <interface-names/5fc421bddec571151748be22/@13a39d43> [interval=60000ms]
2021-11-15T01:06:09.971+01:00 INFO  [LookupTableService] Data Adapter mac-address/5fbab426588a9a48ea9dc2bd [@7816fbb9] RUNNING
2021-11-15T01:06:09.972+01:00 INFO  [LookupDataAdapterRefreshService] Adding job for <mac-address/5fbab426588a9a48ea9dc2bd/@7816fbb9> [interval=60000ms]
2021-11-15T01:06:10.091+01:00 INFO  [LookupTableService] Data Adapter subnets/5fbad765588a9a48ea9dea63 [@154175b3] RUNNING
2021-11-15T01:06:10.092+01:00 INFO  [LookupDataAdapterRefreshService] Adding job for <subnets/5fbad765588a9a48ea9dea63/@154175b3> [interval=60000ms]
2021-11-15T01:06:10.463+01:00 INFO  [LookupTableService] Data Adapter network-aliases/5fc41b5adec571151748b6b4 [@4da9aba0] RUNNING
2021-11-15T01:06:10.464+01:00 INFO  [LookupDataAdapterRefreshService] Adding job for <network-aliases/5fc41b5adec571151748b6b4/@4da9aba0> [interval=60000ms]
2021-11-15T01:06:10.849+01:00 INFO  [LookupTableService] Cache watchlist-cache/61901db34d93d945cb9a709e [@75f361e3] STARTING
2021-11-15T01:06:10.856+01:00 INFO  [LookupTableService] Cache watchlist-cache/61901db34d93d945cb9a709e [@75f361e3] RUNNING
2021-11-15T01:06:10.851+01:00 INFO  [LookupTableService] Cache no-cache/5fbaae33588a9a48ea9dba3e [@1f55441c] STARTING
2021-11-15T01:06:10.873+01:00 INFO  [LookupTableService] Cache no-cache/5fbaae33588a9a48ea9dba3e [@1f55441c] RUNNING
2021-11-15T01:06:10.926+01:00 INFO  [LookupTableService] Starting lookup table SSIDs lookup/5fbaae4b588a9a48ea9dba5b [@4f131e29] using cache no-cache/5fbaae33588a9a48ea9dba3e [@1f55441c], data adapter ssids/5fbaadc2588a9a48ea9db9b9 [@4a925457]
2021-11-15T01:06:10.927+01:00 INFO  [LookupTableService] Starting lookup table MAC Address/5fbab464588a9a48ea9dc304 [@7a4f0950] using cache no-cache/5fbaae33588a9a48ea9dba3e [@1f55441c], data adapter mac-address/5fbab426588a9a48ea9dc2bd [@7816fbb9]
2021-11-15T01:06:10.928+01:00 INFO  [LookupTableService] Starting lookup table Subnet Lookup/5fbad792588a9a48ea9dea97 [@56d7bbaa] using cache no-cache/5fbaae33588a9a48ea9dba3e [@1f55441c], data adapter subnets/5fbad765588a9a48ea9dea63 [@154175b3]
2021-11-15T01:06:10.930+01:00 INFO  [LookupTableService] Starting lookup table Net Alias Lookup/5fc41bc0dec571151748b725 [@3a4e207] using cache no-cache/5fbaae33588a9a48ea9dba3e [@1f55441c], data adapter network-aliases/5fc41b5adec571151748b6b4 [@4da9aba0]
2021-11-15T01:06:10.931+01:00 INFO  [LookupTableService] Starting lookup table Interface Names Lookup/5fc421f3dec571151748be61 [@5491560c] using cache no-cache/5fbaae33588a9a48ea9dba3e [@1f55441c], data adapter interface-names/5fc421bddec571151748be22 [@13a39d43]
2021-11-15T01:06:10.940+01:00 INFO  [LookupTableService] Starting lookup table MAC-SSID/602961b87b867f0b9b1652e3 [@5616c047] using cache no-cache/5fbaae33588a9a48ea9dba3e [@1f55441c], data adapter mac-ssid/602961387b867f0b9b165257 [@5ca767bd]
2021-11-15T01:06:10.942+01:00 INFO  [LookupTableService] Starting lookup table watchlist/61901db34d93d945cb9a70a2 [@3df72bc4] using cache watchlist-cache/61901db34d93d945cb9a709e [@75f361e3], data adapter watchlist-mongo/61901db34d93d945cb9a70a0 [@5d635da0]
2021-11-15T01:06:12.140+01:00 INFO  [IndexRetentionThread] Elasticsearch cluster not available, skipping index retention checks.
2021-11-15T01:06:15.571+01:00 INFO  [JerseyService] Enabling CORS for HTTP endpoint
2021-11-15T01:06:23.281+01:00 INFO  [IndexRangesCleanupPeriodical] Skipping index range cleanup because the Elasticsearch cluster is unreachable or unhealthy
2021-11-15T01:06:43.824+01:00 INFO  [JerseyService] Started REST API at <192.168.37.45:9000>
2021-11-15T01:06:43.836+01:00 INFO  [ServerBootstrap] Services started, startup times in ms: {FailureHandlingService [RUNNING]=65, InputSetupService [RUNNING]=101, LocalKafkaMessageQueueWriter [RUNNING]=148, GracefulShutdownService [RUNNING]=160, BufferSynchronizerService [RUNNING]=209, UrlWhitelistService [RUNNING]=235, LocalKafkaMessageQueueReader [RUNNING]=249, DevelopmentDirectoryObserverService [RUNNING]=260, UserSessionTerminationService [RUNNING]=304, PrometheusExporter [RUNNING]=343, JobSchedulerService [RUNNING]=346, OutputSetupService [RUNNING]=380, LocalKafkaJournal [RUNNING]=432, EtagService [RUNNING]=439, ConfigurationEtagService [RUNNING]=443, ProcessingConfigurationManager [RUNNING]=457, MongoDBProcessingStatusRecorderService [RUNNING]=553, StreamCacheService [RUNNING]=843, PeriodicalsService [RUNNING]=1313, LookupTableService [RUNNING]=3385, JerseyService [RUNNING]=36330}
2021-11-15T01:06:43.848+01:00 INFO  [ServiceManagerListener] Services are healthy
2021-11-15T01:06:43.862+01:00 INFO  [InputSetupService] Triggering launching persisted inputs, node transitioned from Uninitialized [LB:DEAD] to Running [LB:ALIVE]
2021-11-15T01:06:43.990+01:00 WARN  [JobExecutionEngine] Force-released 1 stale job triggers after an unclean job scheduler shutdown
2021-11-15T01:06:44.054+01:00 INFO  [ServerBootstrap] Graylog server up and running.
2021-11-15T01:06:44.058+01:00 INFO  [graylog-auditlog] urn:graylog:node:2f4965ee-d80f-4b81-beca-4aa4bb66bb37 node startup on 2f4965ee-d80f-4b81-beca-4aa4bb66bb37 complete - Graylog v4.2.1+5442e44
2021-11-15T01:06:44.095+01:00 INFO  [InputStateListener] Input [Syslog UDP/5f7884a5add27a240130b7a7] is now STARTING
2021-11-15T01:06:44.115+01:00 INFO  [InputStateListener] Input [GELF UDP/5f802e45bea61154cfb4cbf1] is now STARTING
2021-11-15T01:06:44.124+01:00 INFO  [InputStateListener] Input [Syslog UDP/5f8308e4d7903a2540d4a198] is now STARTING
2021-11-15T01:06:44.133+01:00 INFO  [InputStateListener] Input [Syslog UDP/5f86b8fbd7903a2540d943c8] is now STARTING
2021-11-15T01:06:44.140+01:00 INFO  [InputStateListener] Input [Syslog UDP/5f86b9a9d7903a2540d94507] is now STARTING
2021-11-15T01:06:44.155+01:00 INFO  [InputStateListener] Input [Syslog UDP/5f87159c014cea1d0d56c2e0] is now STARTING
2021-11-15T01:06:44.161+01:00 INFO  [InputStateListener] Input [Syslog UDP/5f9ecadc4687dd05f6c1d0eb] is now STARTING
2021-11-15T01:06:44.166+01:00 INFO  [InputStateListener] Input [GELF UDP/5f8cc561d7f89e1d858eaa77] is now STARTING
2021-11-15T01:06:44.183+01:00 INFO  [InputStateListener] Input [Syslog UDP/5f9f0f674687dd05f6c25d61] is now STARTING
2021-11-15T01:06:44.660+01:00 INFO  [connection] Opened connection [connectionId{localValue:11, serverValue:11}] to localhost:27017
2021-11-15T01:06:44.664+01:00 INFO  [connection] Opened connection [connectionId{localValue:10, serverValue:10}] to localhost:27017
2021-11-15T01:06:44.702+01:00 INFO  [connection] Opened connection [connectionId{localValue:12, serverValue:12}] to localhost:27017
2021-11-15T01:06:44.709+01:00 INFO  [InputStateListener] Input [GELF UDP/6048c91c5690fc59a9739f2f] is now STARTING
2021-11-15T01:06:44.754+01:00 INFO  [connection] Opened connection [connectionId{localValue:13, serverValue:13}] to localhost:27017
2021-11-15T01:06:45.458+01:00 WARN  [UdpTransport] receiveBufferSize (SO_RCVBUF) for input SyslogUDPInput{title=chidi/trinacria, type=org.graylog2.inputs.syslog.udp.SyslogUDPInput, nodeId=2f4965ee-d80f-4b81-beca-4aa4bb66bb37} (channel [id: 0x0bbeafd3, L:/0:0:0:0:0:0:0:0%0:1507]) should be >= 1048576 but is 425984.
2021-11-15T01:06:45.460+01:00 WARN  [UdpTransport] receiveBufferSize (SO_RCVBUF) for input SyslogUDPInput{title=chidi/trinacria, type=org.graylog2.inputs.syslog.udp.SyslogUDPInput, nodeId=2f4965ee-d80f-4b81-beca-4aa4bb66bb37} (channel [id: 0xb8beb9a1, L:/0:0:0:0:0:0:0:0%0:1507]) should be >= 1048576 but is 425984.
2021-11-15T01:06:45.490+01:00 WARN  [UdpTransport] receiveBufferSize (SO_RCVBUF) for input SyslogUDPInput{title=chidi/trinacria, type=org.graylog2.inputs.syslog.udp.SyslogUDPInput, nodeId=2f4965ee-d80f-4b81-beca-4aa4bb66bb37} (channel [id: 0xe78da404, L:/0:0:0:0:0:0:0:0%0:1507]) should be >= 1048576 but is 425984.
2021-11-15T01:06:45.518+01:00 INFO  [InputStateListener] Input [GELF UDP/5f802e45bea61154cfb4cbf1] is now RUNNING
2021-11-15T01:06:45.541+01:00 INFO  [InputStateListener] Input [Syslog UDP/5f7884a5add27a240130b7a7] is now RUNNING
2021-11-15T01:06:45.563+01:00 INFO  [InputStateListener] Input [Syslog UDP/5f9f0f674687dd05f6c25d61] is now RUNNING
2021-11-15T01:06:45.760+01:00 WARN  [UdpTransport] receiveBufferSize (SO_RCVBUF) for input SyslogUDPInput{title=chidi/trinacria, type=org.graylog2.inputs.syslog.udp.SyslogUDPInput, nodeId=2f4965ee-d80f-4b81-beca-4aa4bb66bb37} (channel [id: 0x138f2c06, L:/0:0:0:0:0:0:0:0%0:1507]) should be >= 1048576 but is 425984.
2021-11-15T01:06:45.856+01:00 INFO  [InputStateListener] Input [Syslog UDP/5f8308e4d7903a2540d4a198] is now RUNNING
2021-11-15T01:06:45.912+01:00 INFO  [InputStateListener] Input [GELF UDP/5f8cc561d7f89e1d858eaa77] is now RUNNING
2021-11-15T01:06:45.932+01:00 INFO  [InputStateListener] Input [Syslog UDP/5f86b8fbd7903a2540d943c8] is now RUNNING
2021-11-15T01:06:45.941+01:00 INFO  [InputStateListener] Input [Syslog UDP/5f87159c014cea1d0d56c2e0] is now RUNNING
2021-11-15T01:06:45.973+01:00 INFO  [InputStateListener] Input [Syslog UDP/5f9ecadc4687dd05f6c1d0eb] is now RUNNING
2021-11-15T01:06:45.982+01:00 INFO  [InputStateListener] Input [Syslog UDP/5f86b9a9d7903a2540d94507] is now RUNNING
2021-11-15T01:06:46.032+01:00 INFO  [InputStateListener] Input [GELF UDP/6048c91c5690fc59a9739f2f] is now RUNNING
2021-11-15T02:11:10.921+01:00 INFO  [graylog-auditlog] urn:graylog:node:2f4965ee-d80f-4b81-beca-4aa4bb66bb37 Elasticsearch index range for index "dns_63" deleted
2021-11-15T18:40:24.606+01:00 INFO  [graylog-auditlog] urn:graylog:user:ema session created (from 192.168.37.45)
2021-11-15T18:40:35.243+01:00 INFO  [graylog-auditlog] urn:graylog:user:ema search 61929c2d6564c65444d9bd3f created
2021-11-15T18:40:36.246+01:00 INFO  [graylog-auditlog] urn:graylog:user:ema search job 61929b94a67e764a68832799 for search 61929c2d6564c65444d9bd3f created
Operating system information
Graylog 4.2.1+5442e44 on graylog.private (Debian 11.0.12 on Linux 4.19.0-18-amd64)
Package versions
  • Graylog - 4.2.1
  • MongoDB - 4.2.17
  • Elasticsearch - 7.10.2
  • Apache (reverse proxy) - Apache/2.4.38 (Debian)
The below lines in your log looked interesting and might need some more looking into - some of this may be that you had a forced shutdown. How does your Elasticsearch look? Use this command to check :
curl -XGET "localhost:9200/_cluster/health?pretty"
Concerning log entries:
2021-11-15T01:05:15.327+01:00 WARN [Log] Found a corrupted index file, /var/lib/graylog-server/journal/messagejournal-0/00000000000207983642.index, deleting and rebuilding index…
2021-11-15T01:05:17.572+01:00 INFO [cluster] Cluster created with settings {hosts=[localhost:27017], mode=SINGLE, requiredClusterType=UNKNOWN, serverSelectionTimeout=‘30000 ms’, maxWaitQueueSize=5000}
Adding on to what @tmacgbay suggested. I noticed some configuration that do not look right.
These two settings are the same IP address
So you can leave this one commented out.
The reason why is as shown below, this is also stated in your Graylog configuration file.
# This configuration setting *must not* contain a wildcard address!
[quote="kaaroten, post:1, topic:21761"]
`ERROR [VersionProbe] Unable to retrieve version from Elasticsearch node: Failed to connect to /127.0.0.1:9200. - Connection refused (Connection refused).`
[/quote]
By default, Graylog connects to Elasticsearch using 127.0.0.1 in Graylog configuration file. Does your elasticsearch YAML file have the same address?
Does yours look something like this?
cluster.name: graylog
path.data: /var/lib/elasticsearch
path.logs: /var/log/elasticsearch
network.host: 127.0.0.1
http.port: 9200
discovery.type: single-node
If you going to use localhost make sure it is set in your /etc/hosts file.
127.0.0.1 localhost localhost.localdomain localhost4 localhost4.localdomain4
Just curious, where did you see these settings below at in the documentation? They look like there used for Apache.
EDIT: I see now, those settings are for the commercial feature.
Setting Up Audit log
is "elasticsearch_hosts = http://localhsost:9200 in your server config file?
@tmacgbay
I have to admit that I restored a snapshot taken before upgrading and retried the process, so I’m monitoring the situation right now, because it took one day for my issue to arise. It seems that elasticsearch is fine at the moment, anyways, here’s the output of that command:
  "cluster_name" : "elasticsearch",
  "status" : "green",
  "timed_out" : false,
  "number_of_nodes" : 1,
  "number_of_data_nodes" : 1,
  "active_primary_shards" : 90,
  "active_shards" : 90,
  "relocating_shards" : 0,
  "initializing_shards" : 0,
  "unassigned_shards" : 0,
  "active_shards_percent_as_number" : 100.0
The only thing I changed from the last time is that I stopped the services gracefully before the upgrade.
@gsmith
I missed that piece of information
Thanks, I left it commented now.
My /etc/elasticsearch/elasticsearch.yml file is all commented out. Is there another one elsewhere? I didn’t get it from the configuration.
@Arie
That line is commented out, so I guess it’s the default configuration.
Update: it already started doing it again.
Update: I managed to figure the source: it’s the Telegram Notification Plugin.
Everytime a Telegram notification is sent, the WebUI crashes.
I found the same issue in this post, where it’s said that I have to remove enterprise plugin to be able to get it to work.
Thing is: I need both plugins.
What should I do?
Contact the developer of the plugin and either request and update or offer to help update the code if you can. :slight_smile:
During your install of elasticsearch you should have configured your elasticsearch.yml
It at the bottom of the page.
https://docs.graylog.org/docs/configure
For example here is my lab GL server es.yml file.
[root@graylog elasticsearch]# cat /etc/elasticsearch/elasticsearch.yml | egrep -v "^\s*(#|$)"
network.host: 10.10.6.10
http.port: 9200
path.repo: ["/etc/elasticsearch/my_repo"]
By you stating that elasticsearch.yml file is all commented out, at this point I’m assuming there are some configuration issues happening.
I guess that is the source of the issue and I could only work from GitHub at this point.
