Installation mongo db 5 in debian 11 bullseye... Imposible
I am trying to install GRAYLOG in debian 11 bullseye anda when I try to install mongodb in the pas to put systemctl status mongod, the output is this, we can see “Active failed”, and doesn´t work…
root@santifernvm01:/etc/apt# systemctl status mongod
● mongod.service - MongoDB Database Server
     Loaded: loaded (/lib/systemd/system/mongod.service; enabled; vendor preset: enabled)
     Active: failed (Result: signal) since Mon 2022-12-19 14:21:46 CET; 29min ago
       Docs: https://docs.mongodb.org/manual
    Process: 3208 ExecStart=/usr/bin/mongod --config /etc/mongod.conf (code=killed, signal=ILL)
   Main PID: 3208 (code=killed, signal=ILL)
        CPU: 7ms
Dec 19 14:21:46 santifernvm01 systemd[1]: Started MongoDB Database Server.
Dec 19 14:21:46 santifernvm01 systemd[1]: mongod.service: Main process exited, code=killed, status=4/ILL
Dec 19 14:21:46 santifernvm01 systemd[1]: mongod.service: Failed with result 'signal'.
  • OS Information: debian 11 bullseye, virtualbox 7.0.4
    2 CPU 4gb ram 25gb hard disk
  • Package Version: 5.0
    Yes but i cant put thisone here… Sorry
unistall, and install, take down the demos, and up it again…
until now nothing at all
I hope you can help me so please… Thanlks a lot, best regards, What am i doing wrong?
I would try to install it via the “official” way:
(https://www.mongodb.com/docs/v5.0/tutorial/install-mongodb-on-debian/)
The Graylog guide might have a typo or something like that.
Graylog will update the documentation.
It had some wrong commands in it. One line is 5.x but it should be 5.0. (echo “deb [ arch=amd64 ] MongoDB Repositories bionic/mongodb-org/5.0 multiverse” | sudo tee /etc/apt/sources.list.d/mongodb-org-5.x.list)
The key is for version 4.
This key might work.
sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv f5679a222c647c87527c2f8cb00a0bd1e2c63c11 (edited)
Does the CPU/hypervisor support AVX instructions?
MongoDB 5 requires it. I guess it´s possible to compile it without them, I must check because one of the servers on which I intend to run it has an old CPU.
Looking at the SConstruct file, it would be a simple matter of removing an option and building.
Commenting out line 302 should be enough (see below, 'sandybridge',)
experimental_optimizations = [
    'O3',
    'builtin-memcmp',
    'fnsi',
    'nofp',
    'nordyn',
    'sandybridge',
    'tbaa',
    'treevec',
    'vishidden',
Thanks a lot borjam, if i can it will be tested by myself.
Repeat, thanks a lot.
I need to compile 5 on FreeBSD for a non compliant CPU, will let you know.
that would be perfect.
thanks a lot again.
best regards.
OK it’s simple.
You need to compile it yourself. Follow the developers instructions to build it, but add this option when invoking scons: --experimental-optimization="-sandybridge"
That will remove the Sandybridge requirement from the compilation options. Once you do that, you shouldn’t see any -march=sandybridge compile time option when invoking the compiler.
Good luck! :wink:
For the record, fixing the build for the FreeBSD ports.
5.0 is already patched (waiting for a committer to approve it and commit) and I am testing the same fix for 6.
On the MongoDB forums a developer also recommends to replace -march=sandybridge with -march=nehalem supporting older CPUs but that requires patching the SCons file.
Good morning Borjam
Well I have working graylog 4.3 with elasticsearch 7.9.3 and mongodb 4.4 and now I am trying to put graylog-sidecar with file beat and all works good but I tried to put to work graylog-sidecar with NXLOG and doen´t go good so, can you help with the configuration of NXLOG in debian to send logs to graylog server in a debian 11 machine?
The graylog manual is confuse.
Thanks a lot, really means a lot to me.
Best regards.
Never used any of them (I mean Nxlog, sidecar or filebeat).
Sorry.
OK no problem.
Thanks a lot.
Filebeat goes perfect if you need something, no doubt to call me…
Best regards.
