Fail to start MongoDB
Hello
Mongodb was running fine and for some reason it failed to start now.
I am a newbie …
  • OS Information: Debian 11
  • Package Version: 7.0
 sudo systemctl status  mongod.service
● mongod.service - MongoDB Database Server
     Loaded: loaded (/lib/systemd/system/mongod.service; enabled; vendor preset: enabled)
     Active: failed (Result: exit-code) since Thu 2025-01-23 10:17:47 CET; 11s ago
       Docs: https://docs.mongodb.org/manual
    Process: 934 ExecStart=/usr/bin/mongod --config /etc/mongod.conf (code=exited, status=1/FAILURE)
   Main PID: 934 (code=exited, status=1/FAILURE)
        CPU: 33ms
Jan 23 10:17:47 graylog mongod[934]:   Frame: {"a":"5579C872FC08","b":"5579C0CDD000","o":"7A52C08","s":"_ZN5mongo5logv26detail9doLogImplEiRKNS0_11LogSeverityERKNS0_10LogOptionsENS_10StringDataERKNS0_26TypeErasedAttributeStorageE","C":"mongo::logv2::detail::doLogImpl(int, mo>
Jan 23 10:17:47 graylog mongod[934]:   Frame: {"a":"5579C483A855","b":"5579C0CDD000","o":"3B5D855","s":"_ZN5mongo30initialize_server_global_state46_mongoInitializerFunction_ServerLogRedirectionEPNS_18InitializerContextE","C":"mongo::initialize_server_global_state::_mongoIni>
Jan 23 10:17:47 graylog mongod[934]:   Frame: {"a":"5579C86DD420","b":"5579C0CDD000","o":"7A00420","s":"_ZN5mongo11Initializer19executeInitializersERKSt6vectorINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEESaIS7_EE","C":"mongo::Initializer::executeInitializers(std::ve>
Jan 23 10:17:47 graylog mongod[934]:   Frame: {"a":"5579C86DD9DE","b":"5579C0CDD000","o":"7A009DE","s":"_ZN5mongo21runGlobalInitializersERKSt6vectorINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEESaIS6_EE","C":"mongo::runGlobalInitializers(std::vector<std::__cxx11::bas>
Jan 23 10:17:47 graylog mongod[934]:   Frame: {"a":"5579C47A6569","b":"5579C0CDD000","o":"3AC9569","s":"_ZN5mongo11mongod_mainEiPPc","C":"mongo::mongod_main(int, char**)","s+":"C9"}
Jan 23 10:17:47 graylog mongod[934]:   Frame: {"a":"5579C479F6B5","b":"5579C0CDD000","o":"3AC26B5","s":"main","s+":"C"}
Jan 23 10:17:47 graylog mongod[934]:   Frame: {"a":"7FE6A8775D7A","b":"7FE6A8752000","o":"23D7A","s":"__libc_start_main","s+":"EA"}
Jan 23 10:17:47 graylog mongod[934]:   Frame: {"a":"5579C479F5EA","b":"5579C0CDD000","o":"3AC25EA","s":"_start","s+":"2A"}
Jan 23 10:17:47 graylog systemd[1]: mongod.service: Main process exited, code=exited, status=1/FAILURE
Jan 23 10:17:47 graylog systemd[1]: mongod.service: Failed with result 'exit-code'.
mongodb.log.pdf (68.4 KB)
Reboot, restart service
Please provide some tips for resolving the issue
