New to Graylog. Looking to install on single node on my home network.
First thought was to install on a spare Raspberry Pi 4B 8GB I have.
Saw the instructions here: https://youtu.be/loQ9mzRXlwU from Jeff Darrington and Aaron Sachs from Graylog. Unfortunately, this is v4.3 only not v5. I"m also keen to use Opensearch.
So no dice there.
Acquired a Celeron-based PC and loaded Debian 11. Followed the instructions here: Debian installation
Ran into issues with MongoDB. When I get to:
sudo systemctl start mongod
then:
sudo systemctl status mongod
I get:
mongod.service - MongoDB Database Server
Loaded: loaded (/lib/systemd/system/mongod.service; disabled; vendor preset: enabled)
Active: failed (Result: signal) since Thu 2023-03-09 08:57:26 AEDT; 10s ago
Docs: https://docs.mongodb.org/manual
Process: 3759 ExecStart=/usr/bin/mongod --config /etc/mongod.conf (code=killed, signal=ILL)
Main PID: 3759 (code=killed, signal=ILL)
CPU: 20ms
Mar 09 08:57:26 debian systemd[1]: Started MongoDB Database Server.
Mar 09 08:57:26 debian systemd[1]: mongod.service: Main process exited, code=killed, status=4/ILL
Mar 09 08:57:26 debian systemd[1]: mongod.service: Failed with result 'signal'.
The machine I am trying to install on is a MeEL Q2Q with Celeron J4125 processor w/ 8GB RAM and a clean install of Debian 11
The J4125 is (I think) a “Gemini Lake Refresh” which is circa Nov 2019. Tiger Lake is circa Sep 2020. Reading this post: New to graylog having difficulty installing mongodb and the linked MongoDB doc: https://www.mongodb.com/docs/manual/administration/production-notes/ seems to indicate the isue is that the (3 year old) processor in my PC does not supported.
Is MongoDB really failing because my processor is not supported?
The PC is brand new, out of shrink wrap and I got it specifically to install and run Graylog.
Any help or advice would be appreciated.
