Installation help
Hey All,
I’ve tried a few guides to get graylog running, but I gave up. I came back to the problem a while later and I think I’m working against my self now. Ubuntu 16.04
I want to access from http://graylog.ccc-asimov.ccc.local/ ip address is 192.168.123.9
Mongo and elastic seem to be working, the web page is giving me error. currently “Service Unavailable
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.” but I’ve had many errors.
cat /etc/graylog/server/server.conf
# If you are running more than one instances of graylog2-server you have to select one of these
# instances as master. The master will perform some periodical tasks that non-masters won't perform.
is_master = true
# The auto-generated node ID will be stored in this file and read after restarts. It is a good idea
# to use an absolute file path here if you are starting graylog2-server from init scripts or similar.
password_secret =i3U...iD
#root_username = admin
root_password_sha2 =6...8cf82
# The time zone setting of the root user.
# The configured time zone must be parseable by http://www.joda.org/joda-time/apidocs/org/joda/time/DateTimeZone.html#forID-java.lang.String-
# Default is UTC
root_timezone = -5
#rest_listen_uri =
web_listen_uri = http://192.168.123.9:9000
#web_listen_uri =
# REST API listen URI. Must be reachable by other graylog2-server nodes if you run a cluster.
rest_listen_uri = http://192.168.123.9:9000/api
#rest_lsiten_uri = http://192.168.123.9:12900/
rest_transport_uri = http://192.168.123.9:12900/
rotation_strategy = count
retention_strategy = delete
elasticsearch_shards = 1
elasticsearch_replicas = 0
elasticsearch_index_prefix = graylog2
# be enabled with care. See also: https://www.graylog.org/documentation/general/queries/
allow_highlighting = false
#elasticsearch_discovery_zen_ping_multicast_enabled = false
elasticsearch_discovery_zen_ping_unicast_hosts = 127.0.0.1:9300, 192.168.123.9:9300
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
# Start server with --statistics flag to see buffer utilization.
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
# Enable the disk based message journal.
# The directory which will be used to store the message journal. The directory must me exclusively used by Graylog and
dead_letters_enabled = false
# MongoDB connection string
# See http://docs.mongodb.org/manual/reference/connection-string/ for details
mongodb_uri = mongodb://localhost/graylog2
mongodb_max_connections = 100
# http://api.mongodb.org/java/current/com/mongodb/MongoOptions.html#threadsAllowedToBlockForConnectionMultiplier
load from Elasticsearch
apache config
sudo cat /etc/apache2/sites-enabled/000-default.conf
<VirtualHost *:80>
    ServerName graylog.ccc-asimov.ccc.local
    ProxyRequests Off
    <Proxy *>
        Order deny,allow
        Allow from all
    </Proxy>
    <Location />
        RequestHeader set X-Graylog-Server-URL "http://graylog.ccc-asimov.ccc.local/api/"
        ProxyPass http://127.0.0.1:9000/
        ProxyPassReverse http://127.0.0.1:9000/
    </Location>
</VirtualHost>
sudo cat /etc/graylog/web/web.conf
# graylog2-server REST URIs (one or more, comma separated) For example: "http://127.0.0.1:12900/,http://127.0.0.1:12910/"
graylog2-server.uris="http://127.0.0.1:12900/
# graylog2-server.uris="http://192.168.123.9:12900/"
application.secret="i3...coiD"
application.global=lib.Global
I hate endless logs, but I’ve really been trying…
==> /var/log/apache2/error.log <==
[Thu Mar 29 13:47:23.972962 2018] [proxy:error] [pid 13918] (111)Connection refused: AH00957: HTTP: attempt to connect to 127.0.0.1:9000 (127.0.0.1) failed
[Thu Mar 29 13:47:23.973021 2018] [proxy:error] [pid 13918] AH00959: ap_proxy_connect_backend disabling worker for (127.0.0.1) for 60s
[Thu Mar 29 13:47:23.973031 2018] [proxy_http:error] [pid 13918] [client 192.168.123.21:52819] AH01114: HTTP: failed to make connection to backend: 127.0.0.1
[Thu Mar 29 13:47:24.979008 2018] [proxy:error] [pid 13916] AH00940: HTTP: disabled connection for (127.0.0.1)
what Version of Graylog did you run? This Config look like it is a very ancient version!
You should wipe out whatever you have and start again with the official step-by-step guide: http://docs.graylog.org/en/2.4/pages/installation/os/ubuntu.html
Maybe take another look at these settings.
