Initial Setup Activate Data Node Failed
Initial Setup Data Node Activation Failed
  • OS Information:
    Ubuntu 22.04 LTS
    4* Package Version:
    First node setup with Graylog Open
Try re-install 10 times now. All Services is running fine
Not sure. It is just a simple process @ the end of the whole setup. I am looking for troubleshoot doc. The Data Node how it is communicate with Graylog Server.
work around ? I had used graylog from version 3 and the latest 5.2 so i know way around the configuration. Just need some tips
Thanks for your helps.
Hello @NeoLife-iT,
The Datanode docs can be found here, could you give a little more context as to at what point this setup fails?
I think it is the network a lots of compliance rules in placed so the activation process might be block. I setup @ home lab and it works just fine…so I copy the vm and bring that to work. I redo the setup with open search and it work. What am I missing between having the Data nOde setup vs the Opensearch setup?
