Indexer is not available
  • OS Information:
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=24.04
DISTRIB_CODENAME=noble
DISTRIB_DESCRIPTION="Ubuntu 24.04.2 LTS"
  • Package Version:
graylog-datanode                         6.1.10-1                                amd64        Graylog data node
graylog-server                           6.1.10-1                                amd64        Graylog server
mongodb-org-server                       7.0.18                                  amd64        MongoDB database server
  1. Tried to change the hostname to azne-xyz-xyz
  2. restarted the machine
  3. checked if the service is working or not ( its working )
Below is the error i am facing, I tried to login for the first time using the creds which was mentioned in the Graylog log file as mentioned in the docs and still facing the below issue. First login was done through browser but currently its not loading up on browser too.
INFO  [VersionProbe] Indexer is not available. Retry #5
Unable to retrieve version from indexer node: Hostname azne-xyz-xyz.global.local not verified:
    certificate: sha256/B3ZAzOja/oqY+g56xyzxyzx8uf3npK1m7IB/CqchckU=
    DN: CN=azne-xyz-xyz
    subjectAltNames: [0:0:0:0:0:0:0:1, 127.0.0.1, 10.5.x.x, localhost, azne-xyz-xyz, ip6-localhost]. - Hostname azne-xyz-xyz.global.local not verified:
    DN: CN=azne-xyz-xyz
Note: I have Installed Graylog-server and datanode both on the same node.
Please help me out in resolving this issue.
Hi @docgyan
Can you tell me where is the azne-xyz-xyz.global.local coming from? Is this a hostname hardcoded somewhere? Is this in your datanode.conf or graylog.conf file used somewhere?
The problem is that the certificate generated for your datanode contains only azne-xyz-xyz in SAN and there is no entry with the .global.local suffix that’s being used to access your datanode. So let’s figure out what is coming from where and then we can try to correct the problem or configuration.
Hello, Thank you for responding.
Below are my files:-
datanode conf:
node_id_file = /etc/graylog/datanode/node-id
config_location = /etc/graylog/datanode
password_secret = XXXXXXXXXLSsSNDpOQzzc1gP8e44FRHa2ITzQsNxg48YXieWVEAzWo5jqGkH5MRXAg1B67Ixla9pDgKZHLE-ekAgUXXXXXXX
root_password_sha2 =
opensearch_location = /usr/share/graylog-datanode/dist
opensearch_config_location = /var/lib/graylog-datanode/opensearch/config
opensearch_data_location = /var/lib/graylog-datanode/opensearch/data
opensearch_logs_location = /var/log/graylog-datanode/opensearch
opensearch_heap = 8g
Graylog conf:
is_leader = true
password_secret = XXXXXXXXXLSsSNDpOQzzc1gP8e44FRHa2ITzQsNxg48YXieWVEAzWo5jqGkH5MRXAg1B67Ixla9pDgKZHLE-ekAgXXXXXXXx
root_password_sha2 = fc9b63a79bfd52787b6e93de9befd76acd8971384e3e222222221800bedfef81
http_bind_address = 10.5.X.X:9000
http_publish_uri = http://10.5.X.X:9000/
http_external_uri = http://10.5.X.X:9000/
disabled_retention_strategies = none,close
allow_highlighting = false
field_value_suggestion_mode = on
output_batch_size = 500
output_flush_interval = 1
ring_size = 65536
inputbuffer_ring_size = 65536
message_journal_max_age = 72h
message_journal_max_size =100gb
integrations_scripts_dir = /usr/share/graylog-server/scripts
But i found .global.local been hardcoded under /var/lib/graylog-datanode/opensearch/config/opensearch/opensearch.yml file and i edited it and restarted datanode/graylog services but still no luck.
Let me know if i have missed anything else.
Thanks! The opensearch.yml is regenerated during every datanode restart, so any change you do there won’t be reflected. You have to configure these in datanode.conf.
If your machine can resolve/ping azne-xyz-xyz, then I’d suggest to set
hostname=azne-xyz-xyz
in your datanode.conf and override the hostname autodetection. Then try to restart the datanode/server and check if the connection is ok and there are no errors in logs.
Thanks, this worked!
