Wazuh-Indexer Opensearch to graylog - Host not verified
I am unable to integrate wazuh-indexer opensearch with Graylog
Wazuh AWS AMI - OpenSearch
Graylog latest version
Both on aws , two different Instances
  • OS Information:
    Ubuntu
  • Package Version:
    Latest Graylog 5.0
    2023-01-11T11:01:24.511Z INFO [VersionProbe] Elasticsearch is not available. Retry #619
    2023-01-11T11:01:29.518Z ERROR [VersionProbe] Unable to retrieve version from Elasticsearch node: Hostname 172.22.22.22 not verified:
    certificate: sha256—keyyyyyyyyyyyyyyhere
    DN: CN=wazuh-indexer, OU=Wazuh, O=Wazuh, L=California, C=US
    subjectAltNames: [127.0.0.1]. - Hostname 172.22.22.22 not verified:
    2023-01-11T11:01:29.519Z INFO [VersionProbe] Elasticsearch is not available. Retry #620
    ^C
Tried root-ca certificate of Wazuh-indexer and added it in trusted certs in graylog
how can i perform this process?
The issue lies here:
You are using TLS but your certificate doesn’t have the hostname you are trying to connect to in the SAN, you must add 172.22.22.22 or the actual hostname into your SAN of the certificate and then connect to it correctly.
i have created certificate again , and added it , now getting this error:
nable to retrieve version from Elasticsearch node: PKIX path validation failed: java.security.cert.CertPathValidatorException: Path does not chain with any of the trust anchors. - Path does not chain with any of the trust anchors.
Did you add the full chain of certificates to the Graylog keystore or only the new certificate?
I have used this process ,
mkdir /etc/graylog/server/certs
cp -a /usr/lib/jvm/java-11-openjdk-amd64/lib/security/cacerts /etc/graylog/server/certs/cacerts
keytool -importcert -keystore /etc/graylog/server/certs/cacerts -storepass changeit -alias root_ca -file /etc/graylog/server/certs/rootCA.crt
in here, rootCA.crt file is copied from wazuh-indexer.
How can i add full chain if i havent?
Did you edit /ect/default/graylog-server to point the JVM to your custom truststore? See the bottom of Using HTTPS
In order for the JVM to pick up the new trust store, it has to be started with the JVM parameter -Djavax.net.ssl.trustStore=/path/to/cacerts.jks . If you’ve been using another password to encrypt the JVM trust store than the default changeit , you additionally have to set the JVM parameter -Djavax.net.ssl.trustStorePassword=secret .
I have this configuration.
Path to the java executable.
JAVA=/usr/bin/java
Default Java options for heap and garbage collection.
GRAYLOG_SERVER_JAVA_OPTS=“-Xms1g -Xmx1g -XX:NewRatio=1 -server -XX:+ResizeTLAB -XX:-OmitStackTraceInFastThrow”
Avoid endless loop with some TLSv1.3 implementations.
GRAYLOG_SERVER_JAVA_OPTS=“$GRAYLOG_SERVER_JAVA_OPTS -Djdk.tls.acknowledgeCloseNotify=true”
Fix for log4j CVE-2021-44228
#GRAYLOG_SERVER_JAVA_OPTS=“$GRAYLOG_SERVER_JAVA_OPTS -Dlog4j2.formatMsgNoLookups=true”
GRAYLOG_SERVER_JAVA_OPTS=“$GRAYLOG_SERVER_JAVA_OPTS -Dlog4j2.formatMsgNoLookups=true -Djavax.net.ssl.trustStore=/etc/graylog/server/certs/cacerts -Djavax.net.ssl.trustStorePassword=changeit”
Pass some extra args to graylog-server. (i.e. “-d” to enable debug mode)
GRAYLOG_SERVER_ARGS=“”
Program that will be used to wrap the graylog-server command. Useful to
support programs like authbind.
GRAYLOG_COMMAND_WRAPPER=“”
Tried certification renewal etc. Nothing works.
@kpearson Any Update?
The only thing I can think of, off the top of my head is checking that the root rootCA.crt file you imported is marked as trusted in the keystore and matches the same one that signed your new certificate, you could also just directly import the wazuh indexer certificate and see if that does anything. It’s hard to tell exactly what’s going wrong because the error is clear that the JVM can’t validate the certificate to a trusted authority but I’m not sure why.
Can you post :
cat /etc/wazuh-indexer/opensearch.yml | egrep -v “^\s*(#|$)”
#openssl x509 -subject -nameopt RFC2253 -noout -in yourcert.pem (this should be your cert PEM)
Also refer below discussion to fix the issue :
