Graylog Web UI is not running
Graylog is not binding to the new IP which is changed to 10.35.19.94 from 10.35.4.20
  • OS Information: RHEL 9.6
  • Package Version: Graylog 6.1
    Graylog conf:
    Screenshot 2025-06-18 102228
I did a tail -f /var/log/graylog-server/server.log
Screenshot below for the error:
I have already made the appropriate changes in the mongodb conf, datanode conf and graylog conf but no luck.
If the community can point me in the right direction that would be very helpful.
PS : We have the correct DNS entry.
What changes did you make to datanode.conf
That error is just the certificate complaining that it’s not valid, which is true. It looks like the hostname being presented starts with graylogtest.ucs However the certificate was only set up for graylog.ucs, so its not trusting it. It may have failed back to the IP before since that was also listed, but now that you changed the IP you broke that way to verify the cert.
You will probably want to recreate the certs, which you can do by getting back into the preflight wizard.
You can do this by adding enable_preflight_web = true to server.conf and restart graylog, you will then need to get the temporary login credentials from the end of your server.log file.
Then once you recreate those certs you can remove the line from server.conf to go back to normal operations.
TL;DR: you need to recreate your certs between datanode and graylog.
@Joel_Duffield
The only change I made to the datanode.conf is the new IP and is given below:
mongodb_uri = mongodb://10.35.19.94:27017/graylog
I did as you’ve instructed, and it worked. Thank you so much! :folded_hands:
