Changed IP and Hostname, now Graylog won't start up
I built a new graylog server and it worked. Moved it to a new network and assigned a different IP. Changed the mongo.conf, server.conf and datanode.conf to have the new IP address. Now I get the following error in the datanode log files:
Opensearch REST api of process 2740 unavailable. Cause: Host name 'current ip address’ does not match the certificate subject provided by the peer (CN=COMPUTERNAME)
I am no longer able to access the GUI and I assume this is because the services are not starting correctly.
As this is an initial setup, there is no production data yet.
  • OS Information:
    RHEL 9
  • Package Version:
    6.1
I was trying to figure out how to reset Graylog back to the initial state. I am thinking the generated certificates that are created during the first GUI login are likely the problem. However my attempts to purge the mongodb and other similar endeavors failed.
I’ve read through these forums and found similar but not quite the same problem, none of which were able to help me. Possible I missed something here for sure as I am new to this product.
If anyone has an idea as to how to reset the graylog server so I can get back to the initial config GUI, I feel like that might help. Or if there is a way via command line to reset the offending certificates that would be good also.
Thanks in advance for any help!
@graycon,
You could look to generate new certificates via openssl with the CA that reflect the changes you’ve made.
Which Mongo collections have you removed?
I removed all the Mongo collections that I could (graylog, config and local). I had to leave “Admin”.
After restarting the services (or rebooting the server), the collections are recreated.
I think this person was having the same issue as I am, and asked a similar question. I don’t see an answer there either. Graylog in Docker - Certificate Broken - #2 by webboty
I am open to trying to generate a new certificate, but previously those were done via the web interface GUI, and I am not sure I can replicate everything on my own via command line.
Within the Graylog DB in mongo, I think you could get away with just dropping the data node collection. Dropping the the whole graylog DB would cause all configuration to be nuked.
The Data Node itself will also hang on to configuration and so deleting configuration under /var/lib/graylog-datanode/opensearch/config would also help get back to a preflight state to build new certs.
I dropped the graylog datanodes collection and deleted the config directory. This seems to have fixed the problem!! :tada:
Here are the steps I took to get this done. Your mileage may vary…
mongosh --host *ipaddress*
use graylog
show collections
db.datanodes.drop()
show collections
exit
cd /var/lib/graylog-datanode/opensearch
mv ./config/ ./archive/
mkdir config
chown graylog-datanode:graylog-datanode ./config -R
reboot
Probably could have done this without the reboot, if you wanted to restart services, I admit I took the easy way out.
Got my initial login info from /var/log/graylog-server.log and it worked.
Interestingly after going through the CA initialization again, I was able to log in with the administrator password I set originally (from the first setup about a week ago). So that is one thing that didn’t reset in this process.
Thanks for the help @Wine_Merchant , I appreciate it. I feel like I saw this same question worded about 3 different ways on these forums, with no real answers, so hopefully this will help the next person.
Thanks for describing steps that helped you!
For any future reference - the critical and needed step is to remove the datanode/config/keystore.jks file. This keystore is holding the - now outdated - certificate. If you remove and restart the datanode service, it should be regenerated with a new, correct certificate and correct hostname.
There is a PR that should fix this situation automatically, renewing certificates if the hostname changes and doesn’t match any of the alternative names in the cert: Fix/datanode cert renewal changed hostname by todvora · Pull Request #22057 · Graylog2/graylog2-server · GitHub
Best regards
Tomas
Thanks much for the details and the fix!!
