Failed while provisioning CA to datanodes
Hi guys,
For our school project we try to deploy a Graylog cluster. We’ve succesfully deployed all nodes using the following steps:
However when trying to provisioning our certificates to our datanodes, it gets stuck with the colors of the short node id turning red. When trying to look in the journalctl i couldn’t see any logging while starting the provisioning.
What I do see is that it tries to reach the datanode over https with the hostname and then the port. In our case that is:
https://rj-dn01:9200. However, there is currently no DNS resolving these hostnames. In the server and datanode configuration only IP-addresses are mentioned. It seems that Graylog does this automatically when the data node has reached the graylog server.
  • OS Information:
    Ubuntu 24.04.2 LTS
  • Package Version:
    Graylog 6.2
Tried to check the journalctl logging but couldn’t see any entries. I’m open for other log files that I can check
Look at my story and check if I may have overlooked something
See picture below:
Update; when manually adding the host to /etc/hosts and changing the http_bind_address:rj-dn01:9200 it still won’t work
Hi all, after applying the /etc/hosts to my datanodes this issue got resolved
