How to setup a graylog-datanode 6.1 in cluster
There is trouble to start the Graylog-datanode 6.1.1-1 in a cluster. Have set all the needed parameters according to the posted 6.1 documentation for Graylog-datanode
  • OS Information:
    Debian 12
  • Package Version:
    6.1.5-1 (Updated from 6.1.1-1 8th January 2025)
Gone through all .conf files on graylog application server and on all graylog-datanodes.
Is there any additional software that needs to be installed on the graylog-datanodes? In e.g. opensearch and / or mongodb (client)?
I’ve seen it mentioned an updated version 6.1.4, which repo is that located in? Using ‘downloads.graylog.org’ now, is there another one with more recent software?
Is there an easy way to trigger debug or verbose flags for startup of graylog-datanode and/or graylog-server?
Got the datanodes up, reconfigured the access to MongoDB. Now the applications are running, both Graylog and Datanode.
Another issue with the datanode was access is access rights for LOG and DATA folders.
