Kirt
April 30, 2020, 8:55pm
1
Hi all,
I am trying to create a roll in Graylog 3.2.4, that can read but not create dashboards.
While the users in this roll cannot use the “save” button after they created or edited
a dashboard, they can still use the “save as” button and create additional dashboards
on this way.
I created a roll using the GUI and checked the settings by the REST API:
“name”: “Read-Dashboards”,
“description”: “”,
“permissions”: [
“dashboards:read:5eaad1e9d9ae5e24a94b0d96”,
“streams:read:000000000000000000000003”,
“streams:read:000000000000000000000002”,
“streams:read:000000000000000000000001”,
“dashboards:read:5ea6a1df3140600360412234”
“read_only”: false
Thanks for any hints.
Kirt
shoothub
(Shoothub)
May 5, 2020, 9:03am
2
Check all roles you assigned to user, because they are cummulative. If you assign higher level privileges role to user, this new role cannot works.
Kirt
May 5, 2020, 1:53pm
3
Thanks shoothub.
I tried two setups, but both will allow the user to create a new dashboard by using the “save as” button:
Role “reader” + role “read-Dashboards” (defined as above)
Role “reader” and individual permissions for the user to read streams and dashboards
What will be the correct way to let a user see (some) predefined dashboards without giving him the ability to create additional dashboards?
Kirt
Kirt
May 18, 2020, 2:17pm
4
Hi all,
did anybody successfully set up permissions/roles, as I try to?
I guess it is not uncommon to just allow read access to e.g. first level support without granting such users to create new dashboards.
Any hints are welcome!
Kirt
