How to remove a dashboard highlight
While exploring the Graylog 3.2.3 dashboard features I’ve highlighted a certain field value by clicking on the value in a data table and selecting “highlight the value”.
That worked, but now I would like to remove the highlight but I seem to be overlooking how to accomplish this? Hopefully someone can give me a nudge in the right direction.
Screenshot 2020-03-24 at 10.56.01
he @hkraal
if you expand the sidebar you can click on the trash bin icon to remove the highlight
Ah, the length of my value is too long which causes the trashcan to be out of sight. Time to bring out the development tools to resize the sidebar and file a bug report after I’ve checked that the problem is still present in 3.2.4.
Thanks for your time!
Edit: bug report
