Please help me to find an answer to the easy question “How to install the Correlation Engine”
I have installed Graylog 3.1.4 from a docker-compose file and image (graylog/graylog:3.1.4) using documentation https://docs.graylog.org/en/3.1/pages/installation/docker.html
Also, I have installed enterprise plugin 3.1.4 and I have imported enterprise license (Status: Graylog Plugin Enterprise is installed)
But after a stop/start docker-compose, I still can’t see the Events tab.
In the documentation, I have found nothing about the installation of a correlation engine.
Please help to understand what is wrong?
The configuration is done. To use the correlations you select Alerts > Event Definitions and Create new Event definition. On the second step you can select the correlation:
