I need to host my Graylog URL using proxy server i.e haproxy
i am trying to use Private_IP:9000 in haproxy
backend graylog_cluster
mode http
option http-keep-alive
balance roundrobin
option forwardfor
cookie JSESSIONID prefix
server graylog01 Private-IP:9000 cookie A check
I am able to telnet the from my proxy server ( haproxy )
Private_IP:9000
Please help !!
No worry, issue has been resolved now
jan
(Jan Doberstein)
3
it would be pleaseful if you would share with the community how you have solved your issue and what had helped you!
thanks
Jan
sure @jan
I did the following things…
frontend http
bind 0.0.0.0:80
option forwardfor
http-request add-header X-Forwarded-Host %[req.hdr(host)]
http-request add-header X-Forwarded-Server %[req.hdr(host)]
http-request add-header X-Forwarded-Port %[dst_port]
acl is_graylog hdr_dom(host) -i -m str graylog_url_domain
use_backend graylog if is_graylog
backend graylog
description The Graylog Web backend.
http-request set-header X-Graylog-Server-URL https://graylog_url_domain/api
use-server graylog_1
server graylog_1 Private_IP:9000 maxconn 20 check
I got these details in graylog doc.
http://docs.graylog.org/en/2.4/pages/configuration/web_interface.html#haproxy-1-6
I used lets-encrypt to enable ssl
