Currently, we are running single node Graylog that is running using the Self-signed certificate. We are planning to add one more graylog node and these node’s are going to sit behind HAProxy. I am trying with the following configuration, but didnt get this running.
Config:
frontend graylog_https
bind *:443
mode tcp
default_backend graylog_server_cluster
mode tcp
balance roundrobin
option httpchk HEAD /api/system/lbstatus
http-request set-header X-Graylog-Server-URL https://graylog.example.com/api
server g1 10.10.10.10:9000
server g2 10.10.10.11:9000
with this configuration. I am able to see only the first node and complete cluster is not forming.
I started doubting whether HTTPS is possbile with graylog clusters ? If possible, Can someone point me what mistake I am making here. Thanks
jochen
(Jochen)
January 18, 2018, 12:27pm
2
See http://docs.graylog.org/en/2.4/pages/configuration/web_interface.html#haproxy-1-6 for a working configuration of HAProxy with Graylog 2.4.x.
If you still have problems after reading the documentation, please provide the full configuration of both Graylog nodes and HAProxy.
Hi Jo,
I did follow the document in the link and I couldn’t make it work.
HAProxy:
bind *:443
option forwardfor
http-request add-header X-Forwarded-Host %[req.hdr(host)]
http-request add-header X-Forwarded-Server %[req.hdr(host)]
http-request add-header X-Forwarded-Port %[dst_port]
acl is_graylog hdr_dom(host) -i -m str example.graylog.com
use_backend graylog
backend graylog
description The Graylog Web backend.
balance roundrobin
http-request set-header X-Graylog-Server-URL https://example.graylog.com/api
server graylog1 10.10.10.10:9000 maxconn 20 check
server graylog2 10.10.10.11:9000 maxconn 20 check
GRAYLOG NODE 1:
is_master = true
password_secret = [redacted]
root_password_sha2 = [redacted]
rest_listen_uri = https://10.10.10.10:9000/api/
rest_enable_tls = true
rest_tls_cert_file = /graylog/ssl-keys/Test-Certificate.pem
rest_tls_key_file = /graylog/ssl-keys/Test-PriKey.pem
web_listen_uri = http://10.10.10.10:9000/
web_enable_tls = true
web_tls_cert_file = /graylog/ssl-keys/Test-Certificate.pem
web_tls_key_file = /graylog/ssl-keys/Test-PriKey.pem
elasticsearch_hosts = http://10.10.10.10:9200,http://10.10.10.11:9200
rotation_strategy = count
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 64
outputbuffer_processors = 64
ring_size = 131072
inputbuffer_ring_size = 131072
inputbuffer_processors = 2
message_journal_max_size = 10gb
mongodb_uri = mongodb://10.10.10.10,10.10.10.11/graylog
transport_email_hostname = smtpio.testing.com
transport_email_port = 25
transport_email_use_tls = false
transport_email_subject_prefix = [graylog-alerts]
transport_email_from_email = graylog-alerts@testing.com
transport_email_web_interface_url = https://10.10.10.10:9000
allow_highlighting = true
GRAYLOG NODE 2:
is_master = false
rest_listen_uri = https://10.10.10.11:9000/api/
web_listen_uri = http://10.10.10.11:9000/
ring_size = 131072
transport_email_web_interface_url = https://10.10.10.11:9000
When I try to access https://example.graylog.com page is not opening. Can you help me what I am doing wrong. Thanks
jochen
(Jochen)
January 19, 2018, 8:33am
4
Are the contents of the node ID file unique to each Graylog node?
Have you created a MongoDB replica set or a sharded MongoDB cluster?
And last but not least: Since you’re doing HTTPS termination in HAProxy, you don’t necessarily need to set up HTTPS in Graylog itself.
If you’re using self-signed certificates, make sure to read http://docs.graylog.org/en/2.4/pages/configuration/https.html .
Hi Joe,
Thanks for the suggestion. And I am now terminating SSL on HAProxy itself. But Periodically ( every 2 seconds) I am seeing the below issue in the nodes and I am not able to fully form the cluster.
I am running HAPRoxy on the same host on which I am running graylog master node. Will it make some impact on the API connections?? Can you please suggest ? Thanks
jochen
(Jochen)
January 22, 2018, 8:18am
6
Please answer all of the questions.
Also please post the complete logs of your Graylog nodes.
http://docs.graylog.org/en/2.4/pages/configuration/file_location.html
jan
(Jan Doberstein)
January 22, 2018, 9:15am
7
If the configuration is still as shown in the above configuration for Graylog Node 1 and 2 you have a mixed HTTP/HTTPS Settings in your configuration what is not working and not supported.
You should re-read http://docs.graylog.org/en/2.4/pages/configuration/web_interface.html and http://docs.graylog.org/en/2.4/pages/configuration/https.html
In addition the settings that you are currently use should be posted here…
Thanks for your help Jan. I have found out that time is the culprit here. 2 modes are drifting apart 10 seconds and that was the cause.
After synching time now cluster is stable. Thanks for your assistance on this issue. much appericiated.
