Hi Team,
We have set up a multi node graylog in our environment and trying to connect to the application web browser through haproxy load balancer.
The server.conf at primary node is:
http_bind_address = 10.xx.xx.xx:9000
and config for haproxy at load balancer is:
global
log 127.0.0.1 local0
log 127.0.0.1 local1 notice
maxconn 4096
maxpipes 1024
nogetaddrinfo
user haproxy
group haproxy
daemon
tune.ssl.default-dh-param 2048
ssl-default-bind-ciphers HIGH:!aNULL:!MD5!eNULL:!EXPORT:!DES:!RC4:!3DES:!PSK
defaults
log global
mode http
retries 3
option httplog
option dontlognull
option forwardfor
option http-server-close
##timeout http-keep-alive 1250s
##option http-keep-alive
stats enable
stats auth admin:admin
stats uri /haproxy
timeout server 1200s
timeout connect 20s
timeout client 60s
log 127.0.0.1:514 local0 notice
##default-server inter 500
default-server rise 1
default-server fall 20
frontend Logsearch
bind *:443 ssl crt /etc/certs2019/navigantbpm.com/star_navigantbpm.com.pem no-sslv3 no-tlsv10 no-tlsv11
http-request set-header X-Forwarded-Proto https
http-request add-header X-Forwarded-Host %[req.hdr(host)]
http-request add-header X-Forwarded-Server %[req.hdr(host)]
http-request add-header X-Forwarded-Port %[dst_port]
default_backend Application-nodes
#balance leastconn
balance roundrobin
##option http-tunnel
##option http-server-close
##option prefer-last-server
option httpchk HEAD /api/system/lbstatus
http-request set-header X-Graylog-Server-URL http://10.xx.xx.xx:9000
server trxxxxxxx1 10.xx.xx.xx:9000 weight 1 maxconn 2500 check ##Gray Log Node1
#server trxxxxxxx2 10.xx.xx.xx:9000 weight 1 maxconn 2500 check ##Gray Log Node2
#server trxxxxxxx3 10.xx.xx.xx:9000 weight 1 maxconn 2500 check ##Gray Log Node3
log 127.0.0.1:514 local3 alert
log 127.0.0.1:514 local2 info
And when trying to resolve to the dns entry of load balancer, we get the errors:
and
Closer look in developer mode in network tab gives the status:
(blocked:mixed-content)
Could anyone at least point us in the right direction??
Many Thanks,
Rohit
