Load Balancing Question
Can’t get load balancing to work for web-server (or maybe I don’t understand the concept)
  • OS Information:
    All nodes are Debian 12
  • Package Version:
    5.1.sumthin
    haproxy
frontend www-http
	bind *:80
	option forwardfor
	http-request add-header X-Forwarded-Host %[req.hdr(host)]
	http-request add-header X-Forwarded-Server %[req.hdr(host)]
	http-request add-header X-Forwarded-Port %[dst_port]
	acl is_graylog hdr_dom(host) -i -m str graylog.example.com
	use_backend grayserver
backend grayserver
	balance roundrobin
	option httpchk HEAD /apit/system/libstatus
	http-request set-header X-Graylog-Server-URL http://graylog.example.com/
	server grayserver1 192.168.128.114:9000 maxconn 20 check
	server grayserver2 192.168.128.115:9000 maxconn 20 check
	server grayserver3 192.168.128.116:9000 maxconn 20 check
server.conf (note: every server has the same config except 114 is leader true, 115, 116 is leader false and the below ip’s are consistent (i.e. .114 has .114 in lieu of “xxx”, etc.)
# HTTP settings
#### HTTP bind address
# Default: 127.0.0.1:9000
http_bind_address = 192.168.128.114:9000
#### HTTP publish URI
# The URI will be published in the cluster discovery APIs, so that other Graylog nodes will be able to find and connect to this Graylog node.
# This configuration setting *must not* contain a wildcard address!
http_publish_uri = http://192.168.128.114/
#### External Graylog URI
# Default: $http_publish_uri
http_external_uri = http://graylog.example.com/
#### Enable CORS headers for HTTP interface
# This allows browsers to make Cross-Origin requests from any origin.
# This is disabled for security reasons and typically only needed if running graylog
# with a separate server for frontend development.
# Default: false
#http_enable_cors = false
2-days of google-foo and utilizing the config recommended by Graylog
https://go2docs.graylog.org/5-0/setting_up_graylog/web_interface.htm#making-the-web-interface-work-with-load-balancersproxies
Just hoping there is a solution (well I know there is, I just don’t know it, yet).
Thank you!
hey @accidentaladmin
Not sure what you using for load balancing but @aaronsachs has a pretty good post here for nginx might want to check out his configurations.
