Hi team,
i have multiple graylog for each environment and i wanted to export views from one graylog and import to another graylog, i can not see any option on content pack, can you please help ?
Hi team,
Mongodb stores the settings of the graylog, check it.
But I’m not sure it will work, because graylog uses IDs what will not the same in environments.
you missed what Graylog Version you are using.
I agree, it would be great to have option to export/import views…
Should be given with 3.2
Great to know, it will fire graylog to next level…
