How to define custom field on Event Definition
Dear all:
I want to define custom fields on Event Definition like below show
But when I got the alert & event , it didn’t show any custome fields.
I already test , just two custom fields can be use.
(1) {source.user} (2) {source.srcip}
others fields I define with {source.XXXX} can't be use. I already check my streams , it has fields inside . But I still can't use {source.}…
Can someone show me how to add custom field ?
Thanks!
P.S. My Graylog server version is the latest version 3.3 …
Check my previous post in the past:
Thanks for your reply…
Good job…
But I think , could you provide the pictures to show your solution?
The pictures provide more powerful effect to teach us how to setup the alert mail.
Please~~~~~~~~~~~~~~~
you might want to check the alerting by example part in the docs:
https://docs.graylog.org/en/3.3/pages/alerting/alerting-by-example.html
Thanks for your reply.
I already tried and follow this sop ,but can’t fix my problem.
This sample is the general sample to setup the alert mail…etc.
But I want to suggest official provide more example with pictures show more customized mail alert step by step…
I real real like graplog server be my company’s log server.
So I need more introduction of graylog server with pictures to finish basic function…
Thanks…
