Event Definitions Setup Help
  1. Describe your incident: Needing to create an event definition with an additional field for hostname
Redhat 8
Graylog v4.3.5
  1. What steps have you already taken to try and solve the problem? I have setup a definition that works successfully, but when adding a custom field for Hostname, I get nothing.
I am using the following template
${source.hostname}
I am not sure if this is correct or not.
  1. How can the community help? Point in the proper direction for Event Definitions Template information.
Hey @monarch684
Not sure if thats a template, perhaps if you can share what you configured would help.
Does this help?
Hey @monarch684
Thanks for the added info, What I did was the following for my Active directory.
Example:
This will show up Under alerts.
EDIT:
I also found this for ya, hopeit helps.
