Hi Team,
I have a Jenkins setup on ubuntu 16.04.
I want to build entire Graylog application using Jenkins,
i was using graylog-project-cli to clone repos
how can this be implemented in Jenkins ??
can any one please provide some config on this
vinay
jochen
(Jochen)
2
It should be pretty much straight forwards:
- Clone the git repository
- Run the build instructions from the README file
Is there a specific step which you have issues with?
i’m using graylog-project-cli to clone the repos like this
graylog-project-cli bootstrap '<git hub repo for graylog-project>'
this clones all the required repo with folder structure
graylog-project
graylog-project-repos
now for building we will use mvn inside graylog-project folder
how to replicate all the above steps in Jenkins
ideally jenkins should clone all the repos (plugins ) what i specify and create folder structure and then start building using mvn
can this be done ??
hope you got my point
many thanks
jochen
(Jochen)
4
Yes, and as I said, it should be straight forward. Jenkins supports cloning git repositories and executing arbitrary commands in its build jobs.
With which step do you have your issues?
im trying to create a new project
which type of project i should create is it freestyle/pipelie/… ??
under GitHub project section what configuration i should make so that it clones in graylog-project and graylog-project-repo folder structure
im totally new to Jenkins let me know how can i proceed
Many thanks
jochen
(Jochen)
6
You have to use a “Freestyle” project in order to be able to run arbitrary build steps.
Maybe you better check out the Jenkins CI mailing list at https://groups.google.com/forum/#!forum/jenkinsci-users or their chat at https://jenkins.io/chat/
system
(system)
Closed
7
