How limit entry of records
Hi All,
I wanted to know if there is the possibility of limiting the entry of records, so that some source can not get to saturate my machine.
If I can use the api to know the input of an input, could I limit its use? Could I deactivate an input, if a threshold is exceeded?
Limitation is not possible - you would need to make this at the machine, because in Graylog that is not possible.
