For this small setup running on a study LAB environment i keep on getting ‘limit of total fields has been exceeded’ This with a setup that has not changed profoundly.
As this is a lab setup it sometimes happens machines are disconnected for some time and spew a lot of logs in a short time. Or i enable logs options which generated for more than anticipated.
If with even a small setup this message comes into scope i don’t trust this for a far bigger environment. WIll i be shuffeling index organisation continuously ? Should i consider creating indexes per log type or per device or device group to avoid any messing with number of fields etc ?
