Hi!
What do you think about this problem described below, appreciate any suggestions!
We use nxlog for collecting windows 7: Application, Security, Setup, System logs to graylog.
This creates a lot of fields in graylog, approx. 1115 fields.
Currently we use this nxlog configuration, but it creates a lot of fields in Graylog (automapping ).
<Input eventlogIN>
Module im_msvistalog
<QueryXML>
<QueryList>
<Query Id="0">
<Select Path="Application">*</Select>
<Select Path="Security">*</Select>
<Select Path="Setup">*</Select>
<Select Path="System">*</Select>
</Query>
</QueryList>
</QueryXML>
</Input>
<Output eventlogOUT>
Module om_tcp
Host xxxxxxx
Port 9999999
OutputType GELF_TCP
</Output>
<Route eventlog>
Path eventlogIN => eventlogOUT
</Route>
We want to avoid getting so many fields in graylog(avoiding hitting 1000 fields limit in one index).
The graylog setup A today is:
• 1 graylog input for all 4 logs: Application, Security, Setup, System.
• 1 stream for all 4 logs.
• 1 index for all 4 logs.
We are considering some alternatives,
Alternative setup B:
• 1 graylog input for all 4 logs.
• 1 stream and sream rule for each of the 4 logs(Field Channel must match exactly Security etc))= 4 streams with stream rule.
• 1 index for each of the 4 streams= 4 index.
When we try setup B, my dedicated Security stream still contains 1115 fields.
Alternative setup C:
• 1 graylog input for each of the 4 logs = 4 separate inputs.
• 1 stream for each of the 4 logs= 1 index per input.
• 1 index for each of the 4 logs= 1 index per input.
Any thoughts about this?
BR Andreas
============Update=============
Thanks for the input on this matter @jochen
We decided on “Alternative Setup B”, and it works.
No fields limit warnings.
We also made a “garbage” stream and index that collects anything that’s not captured by the 4 streams and their rules just to be aware of anything “wrong”. We collect about 2500 W7 nxlog clients and it seems ok after 2 weeks.
@Magneton, yes we will probably collect Power shell logs too, as they might contain logs related to security.
We use the event viewer to create queries, that’s a good input on the matter.
Regarding your question about best practice to have individual index for a stream, it seems like a good practice, but as always it depends on the data
