ariel
(ariel)
April 13, 2018, 2:08am
1
I used mongodump to back up graylog’s all files
Now I have an empty graylog, how do I import backups?
I use this command, is this right, How do I modify?
( /etc/graylog/backup , all backup datas in this file)
Looking forward for your reply.
Thank you
jochen
(Jochen)
April 13, 2018, 7:30am
2
With mongorestore .
What issue do you specifically have with restoring the database dump you’ve created before?
ariel
(ariel)
April 13, 2018, 7:51am
3
Hi @jochen
My previous backup process is normal
I put the backup datas on FTP, and then use empty graylog to download.
Error occurred when importing data, graylog says “don’t know what to do with file”
Do you know what i problems with?
Thank you
jochen
(Jochen)
April 13, 2018, 8:19am
4
What did you do exactly and what was the full output of the commands you’ve executed?
ariel
(ariel)
April 16, 2018, 2:06am
5
hi @jochen
Is there any problem with my process?
(put the backup datas on FTP)
(use empty graylog to download)
I upload backup file and download
Content looks normal
Finally I want to restore my backup
My command is " sudo mongrestore -h 127.0.0.1 -d graylog --directoryperdb /etc/graylog/backup "
Thank you
jochen
(Jochen)
April 16, 2018, 7:38am
6
Please refer to the examples in the MongoDB documentation for mongorestore:
https://docs.mongodb.com/manual/reference/program/mongorestore/#examples
system
(system)
Closed
April 30, 2018, 7:52am
7
