Help with stream rule
trying to create stream rule based off the src_ip, wish to have all messages with a src_ip of 192.168. moved into stream, tried using the match regular expression, selected the src_ip field , selected match regular expression, for value, tried various incarnations of , 192\.168\..*\..* seems that the rules test says it worked however messages are not being routed into stream…
  • OS Information: linux
  • Package Version:Graylog 5.2.3+9aee303
tried different incarnations of 192.168....
i’m thinging the wild cards may be the issue , eventually i was trying to create a incoming stream and a out going stream…
this is what worked:
rule “internal”
contains(to_string($message.src_ip), “192.168”)
and
contains(to_string($message.dst_ip), “192.168”)
drop_message();
rules test is not reliable…
Hey @2045kdy
If you trying to route that filed and contain that ip address you need route-to-stream in your pipeline.
example:
  route_to_stream(id: "58cc0a2e2bf0923e5c4b4acc");
