Help needed for Azure AD authentication
We have a Graylog (version: 3.3.6) installation and we need to set up authentication with Azure Active Directory. We have Azure AD Licence: “Azure AD for Office 365”
Is it possible to configure AD authentication with Azure AD using the “Azure AD for Office 365” license?
or Do we need an Azure AD Premium license?
Any help would be highly appreciated.
Thanks,
Arun Sasidharan
Check this MS article, if you are able to create LDAPS connection for Graylog:
I have solved the issue using
Thanks,
Arun Sasidharan
