HA Proxy for collectors using TCP/TLS
Hello Guys,
In our infrastructure we are using the collectors output on TCP/TLS, it was working ok when it was a single node, but now in a cluster environment we been facing a lot of challenges, one of them is the Load balancing, so we were giving a try using HAProxy, does someone have any experience with this, currently we have a running configuration but I feel needs a lot more of work, bellow you will find the configuration, right now it is passing traffic, but the collectors are printing this messages:
2017-11-06 05:47:30 INFO connecting to phxiograylogp01.internal.mcmcg.com:5044
2017-11-06 05:47:30 INFO successfully connected to phxiograylogp01.internal.mcmcg.com:5044
2017-11-06 05:47:30 INFO remote socket was closed during SSL handshake
2017-11-06 05:47:30 INFO reconnecting in 1 seconds
2017-11-06 05:47:31 INFO connecting to phxiograylogp01.internal.mcmcg.com:5047
2017-11-06 05:47:31 INFO successfully connected to phxiograylogp01.internal.mcmcg.com:5047
2017-11-06 05:47:31 INFO remote socket was closed during SSL handshake
2017-11-06 05:47:31 INFO reconnecting in 1 seconds
2017-11-06 05:47:31 INFO connecting to phxiograylogp01.internal.mcmcg.com:5044
2017-11-06 05:47:31 INFO successfully connected to phxiograylogp01.internal.mcmcg.com:5044
# Example configuration for a possible web application.  See the
# full configuration options online.
#   http://haproxy.1wt.eu/download/1.4/doc/configuration.txt
# Global settings
global
    # to have these messages end up in /var/log/haproxy.log you will
    # need to:
    # 1) configure syslog to accept network log events.  This is done
    #    by adding the '-r' option to the SYSLOGD_OPTIONS in
    #    /etc/sysconfig/syslog
    # 2) configure local2 events to go to the /var/log/haproxy.log
    #   file. A line like the following can be added to
    #    local2.*                       /var/log/haproxy.log
    log         127.0.0.1 local2
    chroot      /var/lib/haproxy
    pidfile     /var/run/haproxy.pid
    maxconn     4000
    user        haproxy
    group       haproxy
    daemon
    # turn on stats unix socket
    stats socket /var/lib/haproxy/stats
# common defaults that all the 'listen' and 'backend' sections will
# use if not designated in their block
defaults
    mode                    http
    log                     global
    option                  httplog
    option                  dontlognull
    option http-server-close
    option forwardfor       except 127.0.0.0/8
    option                  redispatch
    retries                 3
    timeout http-request    3s
    timeout queue           1m
    timeout connect         3s
    timeout client          1m
    timeout server          1m
    timeout http-keep-alive 3s
    timeout check port 9000 3s
    maxconn                 3000
# main frontend which proxys to the backends
#frontend  main *:5000
#    acl url_static       path_beg       -i /static /images /javascript /stylesheets
#    acl url_static       path_end       -i .jpg .gif .png .css .js
#    use_backend static          if url_static
#    default_backend             app
# static backend for serving up images, stylesheets and such
#backend static
#    balance     roundrobin
#    server      static 127.0.0.1:4331 check port 9000
# round robin balancing between the various backends
#backend app
#    server  app1 127.0.0.1:5001 check port 9000
#    server  app2 127.0.0.1:5002 check port 9000
#    server  app3 127.0.0.1:5003 check port 9000
#    server  app4 127.0.0.1:5004 check port 9000
listen graylog_5047 :5047
    mode tcp
    option tcplog
    balance roundrobin
    option httpchk HEAD /api/system/lbstatus
    server graylog1 phxiograylogp02.internal.mcmcg.com:5047 check port 9000
    server graylog2 phxiograylogp03.internal.mcmcg.com:5047 check port 9000
    server graylog3 phxiograylogp04.internal.mcmcg.com:5047 check port 9000
listen graylog_5044 :5044
    mode tcp
    option tcplog
    balance roundrobin /api/system/lbstatus
    server graylog1 phxiograylogp02.internal.mcmcg.com:5044 check port 9000
    server graylog2 phxiograylogp03.internal.mcmcg.com:5044 check port 9000
listen graylog_5050 :5050
    mode tcp
    option tcplog
    balance roundrobin
    server graylog1 phxiograylogp02.internal.mcmcg.com:5050 check port 9000
    server graylog2 phxiograylogp03.internal.mcmcg.com:5050 check port 9000
    server graylog3 phxiograylogp04.internal.mcmcg.com:5050 check port 9000
listen graylog_12202 :12202
    mode tcp
    option tcplog
    balance roundrobin
    server graylog1 phxiograylogp02.internal.mcmcg.com:12202 check port 9000
    server graylog2 phxiograylogp03.internal.mcmcg.com:12202 check port 9000
    server graylog3 phxiograylogp04.internal.mcmcg.com:12202 check port 9000
listen graylog_12201 :12201
    mode tcp
    option tcplog
    balance roundrobin
    server graylog1 phxiograylogp02.internal.mcmcg.com:12201 check port 9000
    server graylog2 phxiograylogp03.internal.mcmcg.com:12201 check port 9000
    server graylog3 phxiograylogp04.internal.mcmcg.com:12201 check port 9000
listen graylog_12203 :12203
    mode tcp
    option tcplog
    balance roundrobin
    server graylog1 phxiograylogp02.internal.mcmcg.com:12203 check port 9000
    server graylog2 phxiograylogp03.internal.mcmcg.com:12203 check port 9000
    server graylog3 phxiograylogp04.internal.mcmcg.com:12203 check port 9000
listen graylog_12020 :12020
    mode tcp
    option tcplog
    balance roundrobin
    server graylog1 phxiograylogp02.internal.mcmcg.com:12020 check port 9000
    server graylog2 phxiograylogp03.internal.mcmcg.com:12020 check port 9000
    server graylog3 phxiograylogp04.internal.mcmcg.com:12020 check port 9000
listen graylog_5045 :5045
    mode tcp
    option tcplog
    balance roundrobin
    server graylog1 phxiograylogp02.internal.mcmcg.com:5045 check port 9000
    server graylog2 phxiograylogp03.internal.mcmcg.com:5045 check port 9000
    server graylog3 phxiograylogp04.internal.mcmcg.com:5045 check port 9000
listen graylog_12189 :12189
    mode tcp
    option tcplog
    balance roundrobin
    server graylog1 phxiograylogp02.internal.mcmcg.com:12189 check port 9000
    server graylog2 phxiograylogp03.internal.mcmcg.com:12189 check port 9000
    server graylog3 phxiograylogp04.internal.mcmcg.com:12189 check port 9000
What specific problem do you have? Please provide some context.
Hi @jochen basically I did that configuration but I have no experience using HAProxy, I was wondering If someone have a better idea, and how to integrate the TLS part.
What issue do you have with this HAProxy configuration?
Hello Guys,
Basically what I notice is for example if I go to nodes on graylog and I mark one of them as down, HAProxy mark it as down as well but I get to see on graylog in and out messages.
What does that mean? Could you please elaborate?
for example if I mark as down a server on graylog, I get to see the following message on HAProxy logs:
haproxy[15995]: Server graylog_12201/graylog2 is DOWN, reason: Layer7 wrong status, code: 503, info: “Service Unavailable”, check duration: 49ms. 2 active and 0 backup servers left. 0 sessions active, 0 requeued, 0 remaining in queue.
which is what I expect, but the node keeps receiving data as in bellow image which is dead, but still have in and out messages, on this case the node is actually up and it is just mark it as down, but on a real case it was actually down, I would not like that HAProxy keeps sending data to that node.
