Trying to wrap my head around this, not familiar with Graylog, but hoping to get it to work someday. I am utilizing NGINX Reverse Proxy Manager (NPM) on my network. I am successfully sending data to graylog. However, I get events that looks like this:
facility
Unknown
facility_num
-1
level
-1
message
2025-08-14T12:19:32.982662+02:00q77-npm-01nginx-access[14/Aug/2025:10:19:32 +0000] - 200 200 - GET https graylog.www.xyz "/api/system/configuration/minimum_auto_refresh_interval" [Client 192.168.0.22] [Length 16] [Gzip -] [Sent-to 192.168.44.12] "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/18.6 Safari/605.1.15" "https://monk.www.xyz/streams/689d182f3362d9b1bcbfe4e9/search?q=&rangetype=relative&streams=689d182f3362d9b1bcbfe4e9&from=300"
source
10.0.20.14
timestamp
2025-08-14 10:19:32.983
If I try the above message with this Grok pattern, it works (“Test with Sample Data”), “NPM_ACCESS_LOGS”:
^%{TIMESTAMP_ISO8601:ingest_ts}\s?(?<host>.+?)(?<program>nginx-(?:access|error|stream|proxy))\[%{HTTPDATE:request_time}\] - %{NUMBER:status:int} %{NUMBER:upstream_status:int} - %{WORD:method} %{WORD:scheme} %{HOSTNAME:host_header} "%{DATA:request_path}" \[Client %{IPORHOST:client_ip}\] \[Length %{NUMBER:response_length:int}\] \[Gzip %{DATA:gzip}\] \[Sent-to %{IPORHOST:sent_to}\] "%{DATA:user_agent}" "%{DATA:referrer}"$
But I am not sure why I cannot get the fields when I try to utilize the Pipeline Rule Builder:
Title: NPM Access Logs
When
Check if string value in 'message' contains 'nginx-access'
Then
Match grok pattern 'NPM_ACCESS_LOGS' on field 'message' and set fields for matches
It also looks OK in https://www.grokdebugger.com?
"ingest_ts": "2025-08-14T12:19:32.982662+02:00",
"host": "q77-npm-01",
"program": "nginx-access",
"request_time": "14/Aug/2025:10:19:32 +0000",
"status": 200,
"upstream_status": 200,
"method": "GET",
"scheme": "https",
"host_header": "graylog.www.xyz",
"request_path": "/api/system/configuration/minimum_auto_refresh_interval",
"client_ip": "192.168.0.22",
"response_length": 16,
"gzip": "-",
"sent_to": "192.168.44.12",
"user_agent": "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/18.6 Safari/605.1.15",
"referrer": "https://graylog.www.xyz/streams/689d182f3362d9b1bcbfe4e9/search?q=&rangetype=relative&streams=689d182f3362d9b1bcbfe4e9&from=300"
What am I missing / not understanding? Using Rule Simulation and pasting the contents of the message field in Simple Message gives me Conditions Output true, but noe any fields.
Thanks!
