Grok Pattern in Pipelines
Hello folks,
I am new to Graylog, I started configuring my server, adding stream from my UniFi Gateway (which works perfectly). I am now trying to improve the message log by applying pipelines (since I read not to use extractor anymore). Issue is that I managed to get a Grok pattern working with the extractor but it is not working with my pipeline rule and I don’t know why… Although I am a Network Admin, this is more on the programming side which has never been my forte… Can anyone help me getting started so I can wrap my head around this pipelines function?
This is the raw message:
Gateway [LAN_OUT-RET-20001] DESCR=“VPN - Allowed Servers” IN=br0 OUT=br1 MAC= SRC=192.168.1.100 DST=192.168.2.1 LEN=40 TOS=00 PREC=0x00 TTL=127 ID=9921 DF PROTO=TCP SPT=53629 DPT=80 SEQ=2234031635 ACK=581856961 WINDOW=6142 ACK URGP=0 MARK=1a0000
This is my working Grok Pattern:
Gateway [%{DATA:Direction}] DESCR=“%{DATA:Rule_Description}” IN=%{DATA:From_Network} OUT=%{DATA:To_Network} MAC=%{DATA:mac} SRC=%{IP:Source_IP} DST=%{IP:Destination_IP} LEN=%{INT:length} TOS=%{DATA:tos} PREC=%{DATA:prec} TTL=%{INT:ttl} ID=%{INT:id} %{DATA:flags} PROTO=%{DATA:Protocol} SPT=%{INT:Source_Port} DPT=%{INT:Destination_Port} SEQ=%{INT:seq} ACK=%{INT:ack} WINDOW=%{INT:window} %{DATA:ack_flags} URGP=%{INT:urgp} MARK=%{DATA:mark}
I tried using the Grok simulator, AI, etc. but I am literally stuck…
Thanks in advance!
** Running Graylog 6.0.7+4779d72 on graylog (Eclipse Adoptium 17.0.12 on Linux 5.15.0-122-generic)*
I wouldnt use grok for that as its overkill, i would use some regex to remove the first two values, or grab them if you need them, and then i would use the key value function for the rest, it should make quick work of that and use much less cpu. And its alot easier to write.
Thanks for the reply. The only data in this raw message that I am looking for are:
[LAN_OUT-RET-20001]
IN=br0
OUT=br1
SRC=192.168.1.100
DST=192.168.2.1
PROTO=TCP
SPT=53629
DPT=80
How would I proceed to build my pipeline rule in this case?
hey @idscomm
Use the below to split into fields and then use either remove_single_field or remove_multiple_fields function to drop what is not required.
rule "Key Value"
true
set_fields(
   fields:key_value(
   delimiters:" ",
   kv_delimiters:"="
Thank you for your answer, I will give it a shot later today. Appreciate the help!
