dio99
(Dio99)
April 16, 2020, 1:24pm
1
this line works in grok extractor but not in grok in pipeline
should it not be the same syntax for get it working ? i guess its the " in the pattern but still…
%{IPORHOST:clientip} (?:-|(%{WORD}.%{WORD})) %{USER:ident} [%{HTTPDATE:timestamp}] “(?:%{WORD:verb} %{NOTSPACE:request}(?: HTTP/%{NUMBER:httpversion})?|%{DATA:rawrequest})” %{NUMBER:response} (?:%{NUMBER:bytes}|-) %{QS:referrer} %{QS:agent} %{QS:forwarder}
// Anders
tmacgbay
(Tmacgbay)
April 16, 2020, 3:26pm
2
It would help if you posted the rule you were trying to get to work so we could see it in context.
That being said you are on the right track, you have to escape “special” things like quotes to have them in the pipeline.
Should be:
dio99
(Dio99)
April 16, 2020, 6:29pm
3
hi yes but the thing is that the rule works in extractor that but not in the pipeline…
and thanks for the info that i need to esc it out…
dio99
(Dio99)
April 16, 2020, 8:23pm
4
rule “[NGINX] parse nginx access”
has_field(“message”)
let mess = to_string($message.message);
let parsed = grok(pattern: “%{IPORHOST:clientip} (?:-|(%{WORD}.%{WORD})) %{USER:ident} [%{HTTPDATE:timestamp}] “(?:%{WORD:verb} %{NOTSPACE:request}(?: HTTP/%{NUMBER:httpversion})?|%{DATA:rawrequest})” %{NUMBER:response} (?:%{NUMBER:bytes}|-) %{QS:referrer} %{QS:agent} %{QS:forwarder}”, value: mess, only_named_captures: true);
set_fields(parsed);
dio99
(Dio99)
April 16, 2020, 8:45pm
5
i added the pattern in Grok patterns
NGINX_ACCESS %{IPORHOST:clientip} (?:-|(%{WORD}.%{WORD})) %{USER:ident} [%{HTTPDATE:timestamp}] “(?:%{WORD:verb} %{NOTSPACE:request}(?: HTTP/%{NUMBER:httpversion})?|%{DATA:rawrequest})” %{NUMBER:response} (?:%{NUMBER:bytes}|-) %{QS:referrer} %{QS:agent} %{QS:forwarder}
then added it in the pipeline now it works
let parsed = grok(pattern: “%{NGINX_ACCESS}”, value: mess, only_named_captures: true);
set_fields(parsed);
jan
(Jan Doberstein)
April 23, 2020, 7:31am
6
you have quotes that in the message - and other characters that need to be quoted in the processing pipeline.
That is the reason - AFAIK
