Hi Team,
I am running v3.1.4. I have a Grok Pattern to extract values from a stream and that is working fine.
I was trying to create a Dashboard Widget to display the value of one of the fields extracted from the Grok Pattern vs time. Not able to get that completed.
I do see the Value and its Count as part of the Quick Values but that is not what i want.
For ex: -
I want to create a Widget to Display the Fields Value vs Time and would like to sort it with the Source that the Stream is sent from.
Is this possible to do on Graylog?
Any help is appreciated.
Thanks,
Vibhor
