Hello guys.
I’ve decided to setup Graylog this way:
- one server with graylog & mongodb (server IP address: 10.200.125.48);
- another server with elasticsearch (server IP address: 10.200.125.49).
Both server OS is CentOS 7.
But have error in server.log file and WEB interface doesn’t starting:
2017-03-20T10:49:42.626+03:00 INFO [zen] [graylog-22487182-1142-4dff-9731-352a466f3979] failed to send join request to master [{es-node-1}{NgVm0J_hRRqKXhOLwkiTRA}{10.200.125.49}{10.200.125.49:9300}], reason [RemoteTransportException[[es-node-1][10.200.125.49:9300][internal:discovery/zen/join]]; nested: ConnectTransportException[[graylog-22487182-1142-4dff-9731-352a466f3979][127.0.0.1:9350] connect_timeout[30s]]; nested: NotSerializableExceptionWrapper[connect_exception: Connection refused: /127.0.0.1:9350]; ]
elasticsearch.yml:
cluster.name: graylog
node.name: es-node-1
path.data: /es/data
path.logs: /es/log
network.host: 10.200.125.49
http.port: 9200
discovery.zen.ping.multicast.enabled: false
discovery.zen.ping.unicast.hosts: [“10.200.125.49:9300”]
discovery.zen.minimum_master_nodes: 1
server.conf
is_master = true
password_secret = SOME#######################################
root_password_sha2 = SOME#######################################
root_timezone = Asia/Kuwait
rest_listen_uri = http://10.200.125.48:12900/
rotation_strategy = count
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
allow_highlighting = false
elasticsearch_cluster_name = graylog
elasticsearch_discovery_zen_ping_unicast_hosts = 10.200.125.49:9300
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
I supposed there are some errors in my config files but I cannot find them - pls help. ![]()
