Failed to send join request to master
Newly I have installed Graylog server, version Graylog v2.2.1+4829190 which is not connecting with Elastic cluster and getting below error messages.
In Webpage:
Elasticsearch cluster unavailable (triggered 2 days ago)
Graylog could not successfully connect to the Elasticsearch cluster. If you’re using multicast, check that it is working in your network and that Elasticsearch is accessible. Also check that the cluster name setting is correct. Read how to fix this in the Elasticsearch setup documentation.
tailf /var/log/graylog-server/server.log
2017-02-24T11:41:25.482+05:30 INFO [zen] [graylog-9961b166-b690-439d-8319-706ccfa8c3b3] failed to send join request to master [{Node-1}{CSmhvv7DScqPSDIVL4XZlg}{172.20.246.42}{10.0.0.2:9300}{master=true}], reason [RemoteTransportException[[Node-1][10.0.0.2:9300][internal:discovery/zen/join]]; nested: ConnectTransportException[[graylog-9961b166-b690-439d-8319-706ccfa8c3b3][127.0.0.1:9300] connect_timeout[30s]]; nested: NotSerializableExceptionWrapper[connect_exception: Connection refused: /127.0.0.1:9300]; ]
Configurations:
Graylog:
is_master = true
password_secret = xxxxxxxxx
root_password_sha2 = xxxxxxxxxxxx
root_timezone = Asia/Kolkata
rest_listen_uri = http://10.0.0.3:12900/api/
rest_thread_pool_size = 16
web_listen_uri = http://10.0.0.3:9000/
web_thread_pool_size = 16
rotation_strategy = count
elasticsearch_max_time_per_index = 30d
retention_strategy = delete
elasticsearch_shards = 2
elasticsearch_replicas = 0
elasticsearch_index_prefix = NetworkLogs
allow_highlighting = false
elasticsearch_cluster_name = Analytics
elasticsearch_discovery_zen_ping_unicast_hosts = 10.0.0.2:9300
elasticsearch_discovery_zen_ping_multicast_enabled = false
elasticsearch_transport_tcp_port = 9300
elasticsearch_cluster_discovery_timeout = 5000
elasticsearch_discovery_initial_state_timeout = 10s
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
mongodb_uri = mongodb://10.0.0.3:27017/graylog
Elasticsearch:
Version - elasticsearch-2.4.3-1.noarch
cluster.name: Analytics
node.master: true
node.data: true
node.name: Node-1
path.data: /elastic/data
script.inline: on
script.indexed: on
bootstrap.mlockall: true
indices.store.throttle.max_bytes_per_sec: 150mb
network.host: 10.0.0.2
http.port: 9200
http.enabled: true
discovery.zen.ping.unicast.hosts: [“10.0.0.2:9300”]
discovery.zen.ping.multicast.enabled: false
Elastic cluster health:
1487917526 11:55:26 Analytics green 1 1 0 0 0 0 0 0 - 100.0%
After this when I added elasticsearch_network_host = 10.0.0.2 in graylog configuration the graylog web goes down and getting below error,
2017-02-24T11:59:00.200+05:30 ERROR [ServerBootstrap] Graylog startup failed. Exiting. Exception was:
java.lang.IllegalStateException: Expected to be healthy after starting. The following services are not running: {STARTING=[JerseyService [STARTING]], FAILED=[IndexerSetupService [FAILED]]}
at com.google.common.util.concurrent.ServiceManager$ServiceManagerState.checkHealthy(ServiceManager.java:742) ~[graylog.jar:?]
at com.google.common.util.concurrent.ServiceManager$ServiceManagerState.awaitHealthy(ServiceManager.java:555) ~[graylog.jar:?]
at com.google.common.util.concurrent.ServiceManager.awaitHealthy(ServiceManager.java:304) ~[graylog.jar:?]
at org.graylog2.bootstrap.ServerBootstrap.startCommand(ServerBootstrap.java:147) [graylog.jar:?]
at org.graylog2.bootstrap.CmdLineTool.run(CmdLineTool.java:209) [graylog.jar:?]
at org.graylog2.bootstrap.Main.main(Main.java:44) [graylog.jar:?]
2017-02-24T11:59:00.215+05:30 INFO [Server] SIGNAL received. Shutting down.
2017-02-24T11:59:00.229+05:30 INFO [GracefulShutdown] Graceful shutdown initiated.
2017-02-24T11:59:00.233+05:30 INFO [GracefulShutdown] Node status: [Halting [LB:DEAD]]. Waiting <3sec> for possible load balancers to recognize state change.
2017-02-24T11:59:00.233+05:30 WARN [DeadEventLoggingListener] Received unhandled event of type <org.graylog2.plugin.lifecycles.Lifecycle> from event bus <AsyncEventBus{graylog-eventbus}>
2017-02-24T11:59:04.236+05:30 INFO [GracefulShutdown] Goodbye.
Thanks in advance,
rajkumar
Have you checked the firewall settings in both servers so that they allow connections for the necessary ports?
SElinux & IP Tables are flushed and disabled. also able to telnet on 9300 from graylog to ES node
What’s the public IP of your Graylog ES node?
Per the docs - http://docs.graylog.org/en/2.2/pages/configuration/elasticsearch.html
Additionally, Graylog has to use a network interface for the embedded Elasticsearch node which the other Elasticsearch nodes in the cluster can connect to:
# Public IP address or host name of the Graylog node, accessible for the other Elasticsearch nodes
elasticsearch_network_host = 198.51.100.23
Thank you Bill Murrin,
my bad I have specified Elastic IP in elasticsearch_network_host. after chenging it into graylog IP both the clusters able to connect.
