Can not Login to Web Gui of latest Graylog
Hi I spent 2 days trying to install Graylog like 6 times and spent hours online to get it to work.
I am unsuccessful and need help.
Is Graylog only designed to be working for local network only ? 127.0.0.1 ? i know by default that is the set up.
I have installation on remote server online and can not log in to it at all.
What i have:
  • Container on Digital Ocean with Ubuntu 20.04 LTS
  • Firewall not activated ( Disabled )
  • Java 11 installed
i followed multiple instructions on line none worked for external access, i dont know for local if it works since i dont have access to local infrustructure.
I also followed 3 times this tutorial.
https://docs.graylog.org/docs/ubuntu
here are my configs i have at the moment:
Again all services Elastic Search, Graylog, MongoDB is active and working
Why i can not access the webpage and login screen on port 9000 using the browser…
Please help i just ran out of info online.
due to not enough space i had to break up logs in following posts :frowning:
i dont know how to post logs here it says i use over 32000 characters that is the limit here so i will try to attache text files as hyperlink because i ran out of ideas.
https://pomoconline.com/info/graylogconfig.txt
https://pomoconline.com/info/Elasticsearch.txt
here is more info when i run command
ā€œtail -f /var/log/graylog-server/server.logā€
Need further help?
* Official documentation: http://docs.graylog.org/
* Community support: https://www.graylog.org/community-support/
* Commercial support: https://www.graylog.com/technical-support/
Terminating. :(
2022-07-28T12:47:26.708Z INFO  [CmdLineTool] Loaded plugin: AWS plugins 4.0.17 [org.graylog.aws.AWSPlugin]
2022-07-28T12:47:26.713Z INFO  [CmdLineTool] Loaded plugin: Collector 4.0.17 [org.graylog.plugins.collector.CollectorPlugin]
2022-07-28T12:47:26.715Z INFO  [CmdLineTool] Loaded plugin: Threat Intelligence Plugin 4.0.17 [org.graylog.plugins.threatintel.ThreatIntelPlugin]
2022-07-28T12:47:26.715Z INFO  [CmdLineTool] Loaded plugin: Elasticsearch 6 Support 4.0.17+d0c5b22 [org.graylog.storage.elasticsearch6.Elasticsearch6Plugin]
2022-07-28T12:47:26.721Z INFO  [CmdLineTool] Loaded plugin: Elasticsearch 7 Support 4.0.17+d0c5b22 [org.graylog.storage.elasticsearch7.Elasticsearch7Plugin]
2022-07-28T12:47:26.982Z INFO  [CmdLineTool] Running with JVM arguments: -Xms1g -Xmx1g -XX:NewRatio=1 -XX:+ResizeTLAB -XX:-OmitStackTraceInFastThrow -Djdk.tls.acknowledgeCloseNotify=true -Dlog4j2.formatMsgNoLookups=true -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUnloadingEnabled -Dlog4j.configurationFile=file:///etc/graylog/server/log4j2.xml -Djava.library.path=/usr/share/graylog-server/lib/sigar -Dgraylog2.installation_source=deb
2022-07-28T12:47:27.226Z INFO  [Version] HV000001: Hibernate Validator null
2022-07-28T12:47:30.171Z INFO  [InputBufferImpl] Message journal is enabled.
2022-07-28T12:47:30.190Z INFO  [NodeId] Node ID: e2ffbd47-dadc-4d00-9abe-fca2e5597e1a
2022-07-28T12:47:30.372Z INFO  [LogManager] Loading logs.
2022-07-28T12:47:30.419Z WARN  [Log] Found a corrupted index file, /var/lib/graylog-server/journal/messagejournal-0/00000000000000000000.index, deleting and rebuilding index...
2022-07-28T12:47:30.469Z INFO  [LogManager] Logs loading complete.
2022-07-28T12:47:30.472Z INFO  [KafkaJournal] Initialized Kafka based journal at /var/lib/graylog-server/journal
2022-07-28T12:47:30.496Z INFO  [cluster] Cluster created with settings {hosts=[localhost:27017], mode=SINGLE, requiredClusterType=UNKNOWN, serverSelectionTimeout='30000 ms', maxWaitQueueSize=5000}
2022-07-28T12:47:30.547Z INFO  [cluster] Cluster description not yet available. Waiting for 30000 ms before timing out
2022-07-28T12:47:30.578Z INFO  [connection] Opened connection [connectionId{localValue:1, serverValue:99}] to localhost:27017
2022-07-28T12:47:30.582Z INFO  [cluster] Monitor thread successfully connected to server with description ServerDescription{address=localhost:27017, type=STANDALONE, state=CONNECTED, ok=true, version=ServerVersion{versionList=[3, 6, 8]}, minWireVersion=0, maxWireVersion=6, maxDocumentSize=16777216, logicalSessionTimeoutMinutes=30, roundTripTimeNanos=2539068}
2022-07-28T12:47:30.601Z INFO  [connection] Opened connection [connectionId{localValue:2, serverValue:100}] to localhost:27017
2022-07-28T12:47:31.040Z INFO  [InputBufferImpl] Initialized InputBufferImpl with ring size <65536> and wait strategy <BlockingWaitStrategy>, running 2 parallel message handlers.
2022-07-28T12:47:31.755Z ERROR [VersionProbe] Unable to retrieve version from Elasticsearch node:
java.net.ConnectException: Failed to connect to /127.0.0.1:9200
        at okhttp3.internal.connection.RealConnection.connectSocket(RealConnection.java:265) ~[graylog.jar:?]
        at okhttp3.internal.connection.RealConnection.connect(RealConnection.java:183) ~[graylog.jar:?]
        at okhttp3.internal.connection.ExchangeFinder.findConnection(ExchangeFinder.java:224) ~[graylog.jar:?]
        at okhttp3.internal.connection.ExchangeFinder.findHealthyConnection(ExchangeFinder.java:108) ~[graylog.jar:?]
        at okhttp3.internal.connection.ExchangeFinder.find(ExchangeFinder.java:88) ~[graylog.jar:?]
        at okhttp3.internal.connection.Transmitter.newExchange(Transmitter.java:169) ~[graylog.jar:?]
        at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.java:41) ~[graylog.jar:?]
        at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:142) ~[graylog.jar:?]
        at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:117) ~[graylog.jar:?]
        at okhttp3.internal.cache.CacheInterceptor.intercept(CacheInterceptor.java:94) ~[graylog.jar:?]
        at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.java:88) ~[graylog.jar:?]
        at okhttp3.RealCall.getResponseWithInterceptorChain(RealCall.java:229) ~[graylog.jar:?]
        at okhttp3.RealCall.execute(RealCall.java:81) ~[graylog.jar:?]
        at retrofit2.OkHttpCall.execute(OkHttpCall.java:204) ~[graylog.jar:?]
        at org.graylog2.storage.versionprobe.VersionProbe.rootResponse(VersionProbe.java:120) ~[graylog.jar:?]
        at org.graylog2.storage.versionprobe.VersionProbe.probe(VersionProbe.java:73) ~[graylog.jar:?]
        at java.util.stream.ReferencePipeline$3$1.accept(ReferencePipeline.java:195) ~[?:?]
        at java.util.Collections$2.tryAdvance(Collections.java:4747) ~[?:?]
        at java.util.stream.ReferencePipeline.forEachWithCancel(ReferencePipeline.java:127) ~[?:?]
        at java.util.stream.AbstractPipeline.copyIntoWithCancel(AbstractPipeline.java:502) ~[?:?]
        at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:488) ~[?:?]
        at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:474) ~[?:?]
        at java.util.stream.FindOps$FindOp.evaluateSequential(FindOps.java:150) ~[?:?]
        at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234) ~[?:?]
        at java.util.stream.ReferencePipeline.findFirst(ReferencePipeline.java:543) ~[?:?]
        at org.graylog2.storage.versionprobe.VersionProbe.probe(VersionProbe.java:54) ~[graylog.jar:?]
        at org.graylog2.storage.providers.ElasticsearchVersionProvider.lambda$get$1(ElasticsearchVersionProvider.java:68) ~[graylog.jar:?]
        at org.graylog2.storage.providers.AtomicCache.get(AtomicCache.java:36) [graylog.jar:?]
        at org.graylog2.storage.providers.ElasticsearchVersionProvider.get(ElasticsearchVersionProvider.java:67) [graylog.jar:?]
        at org.graylog2.storage.providers.ElasticsearchVersionProvider.get(ElasticsearchVersionProvider.java:35) [graylog.jar:?]
        at com.google.inject.internal.ProviderInternalFactory.provision(ProviderInternalFactory.java:85) [graylog.jar:?]
        at com.google.inject.internal.BoundProviderFactory.provision(BoundProviderFactory.java:77) [graylog.jar:?]
        at com.google.inject.internal.ProviderInternalFactory.circularGet(ProviderInternalFactory.java:59) [graylog.jar:?]
        at com.google.inject.internal.BoundProviderFactory.get(BoundProviderFactory.java:61) [graylog.jar:?]
        at com.google.inject.internal.ProviderToInternalFactoryAdapter.get(ProviderToInternalFactoryAdapter.java:40) [graylog.jar:?]
        at com.google.inject.internal.SingletonScope$1.get(SingletonScope.java:168) [graylog.jar:?]
        at com.google.inject.internal.InternalFactoryToProviderAdapter.get(InternalFactoryToProviderAdapter.java:39) [graylog.jar:?]
        at com.google.inject.internal.SingleParameterInjector.inject(SingleParameterInjector.java:42) [graylog.jar:?]
        at com.google.inject.internal.SingleParameterInjector.getAll(SingleParameterInjector.java:65) [graylog.jar:?]
        at com.google.inject.internal.ConstructorInjector.provision(ConstructorInjector.java:113) [graylog.jar:?]
        at com.google.inject.internal.ConstructorInjector.construct(ConstructorInjector.java:91) [graylog.jar:?]
        at com.google.inject.internal.ConstructorBindingImpl$Factory.get(ConstructorBindingImpl.java:306) [graylog.jar:?]
        at com.google.inject.internal.BoundProviderFactory.get(BoundProviderFactory.java:60) [graylog.jar:?]
        at com.google.inject.internal.FactoryProxy.get(FactoryProxy.java:62) [graylog.jar:?]
        at com.google.inject.internal.RealMultibinder$RealMultibinderProvider.doProvision(RealMultibinder.java:198) [graylog.jar:?]
        at com.google.inject.internal.RealMultibinder$RealMultibinderProvider.doProvision(RealMultibinder.java:151) [graylog.jar:?]
        at com.google.inject.internal.InternalProviderInstanceBindingImpl$Factory.get(InternalProviderInstanceBindingImpl.java:113) [graylog.jar:?]
        at com.google.inject.internal.SingleFieldInjector.inject(SingleFieldInjector.java:52) [graylog.jar:?]
        at com.google.inject.internal.MembersInjectorImpl.injectMembers(MembersInjectorImpl.java:147) [graylog.jar:?]
        at com.google.inject.internal.ConstructorInjector.provision(ConstructorInjector.java:124) [graylog.jar:?]
        at com.google.inject.internal.InternalInjectorCreator.loadEagerSingletons(InternalInjectorCreator.java:211) [graylog.jar:?]
        at com.google.inject.internal.InternalInjectorCreator.injectDynamically(InternalInjectorCreator.java:182) [graylog.jar:?]
        at com.google.inject.internal.InternalInjectorCreator.build(InternalInjectorCreator.java:109) [graylog.jar:?]
        at com.google.inject.Guice.createInjector(Guice.java:87) [graylog.jar:?]
        at org.graylog2.shared.bindings.GuiceInjectorHolder.createInjector(GuiceInjectorHolder.java:34) [graylog.jar:?]
        at org.graylog2.bootstrap.CmdLineTool.setupInjector(CmdLineTool.java:381) [graylog.jar:?]
        at org.graylog2.bootstrap.CmdLineTool.run(CmdLineTool.java:196) [graylog.jar:?]
Caused by: java.net.ConnectException: Connection refused (Connection refused)
        at java.net.PlainSocketImpl.socketConnect(Native Method) ~[?:?]
        at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:412) ~[?:?]
        at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:255) ~[?:?]
        at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:237) ~[?:?]
        at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392) ~[?:?]
        at java.net.Socket.connect(Socket.java:609) ~[?:?]
        at okhttp3.internal.platform.Platform.connectSocket(Platform.java:130) ~[graylog.jar:?]
        at okhttp3.internal.connection.RealConnection.connectSocket(RealConnection.java:263) ~[graylog.jar:?]
        ... 125 more
2022-07-28T12:47:31.791Z INFO  [ProcessBuffer] Initialized ProcessBuffer with ring size <65536> and wait strategy <BlockingWaitStrategy>.
2022-07-28T12:47:31.857Z INFO  [ProcessBuffer] Initialized ProcessBuffer with ring size <65536> and wait strategy <BlockingWaitStrategy>.
2022-07-28T12:47:32.078Z INFO  [ProcessBuffer] Initialized ProcessBuffer with ring size <65536> and wait strategy <BlockingWaitStrategy>.
Looks at first that your ES is not reachable internally.
Should be something like this:
grep -v "#" /etc/elasticsearch/elasticsearch.yml
cluster.name: graylog
node.name: <your.node.name>
path.data: /var/lib/elasticsearch
path.logs: /var/log/elasticsearch
network.host: <your-host-ip>
http.port: 9200
discovery.seed_hosts: ["<your-host-ip>"]
cluster.initial_master_nodes: ["<your-host-ip>"]
and in graylog this should could be for elasticserch:
elasticsearch_hosts = http://<your-host-ip>:9200
Do nog go beyond version 7.10.2 for elasticsearch for it is not supported bij graylog and
install the open (OSS) version of it.
In graylog server.conf, use the ip addres of your remote server at http_bind_addres and see if that works for remote acces.
Good luck
@PeterR
I agree with @Arie Thos configuration should be set correctly.
For Graylog to connect to Elasticsearch two configuration are essential
Graylog Configuration file
  • Elasticsearch_hosts is set for default 127.0.0.1
Elasitcsearch YAML file
  • network.host is set for default 127.0.0.1
That configuration would mean Elasticsearch and Graylog are on the same node.
  • Elasticsearch_hosts is set for default 192.168.1.100
  • network.host is set for default 192.168.1.100
That configuration would mean Elasticsearch and Graylog are on different nodes or in a cluster.
Thank you for replies…
In official install instruction, there is no single mention about the changes that are recommended in your replies… very strange that important pieces like that should be included in instructions.
I noticed that my mongoldb is no longer working so I will do another clean installation tomorrow and include suggested changes in config files…
question:
in all suggested ā€œā€ areas I use public ip correct?
thank you and I will redo install tomorrow and include suggested fixes.
I agree, But that why were here helping :smiley:
In your special case, you could keep some things at 127.0.0.1 as they are local traffic.
So elasticsearch (port 9200) should be there, just like monogo (port 27107) so that
Graylog can reach them internally.
Hi Arie
could you tell me which line I should leave as loopback 127.0.0.1 in configs?
Thnaks
http.port: 9200
Ok I gave up
I followed as much as I could and I still can not get it to work
here are my latest config files for review:
Please help
Please message me directly if someone is willing to help me and I will provide the info to help me get it to work.
Please help
I tried that tutorial
however it install older version of Elasticsearch 6
and Graylog 4.1
however that instruction worked like a charm
anybody can clarify why original instruction fails?
https://docs.graylog.org/v1/docs/ubuntu
thanks
Peter,
Sorry for not reading your reply correct.
Everything concerning elasticsearch could default to 127.0.0.1
in the es and graylog config.
Hi
ok latest versions not working
Vultur tutorial that install old Graylog 4.1 and Elasticsearch 6.8
is the only installation that works for me…
Anybody has the latest versions working in Ubuntu 20?
Graylog 4.3.2
ElasticSearch 7.10.2
Anybody willing to help here?
Hello @PeterR
I have, I’m running GL 4.3.0, ES 7.10, Mongo 4.4 using these instruction
along with some network configuration on my Linux box.
EDIT: Running HTTPS on the front end. here are some of my configurations.
GL-Config
[root@graylog graylog]# cat /etc/graylog/server/server.conf | egrep -v "^\s*(#|$)"
is_master = true
password_secret =epOqmL
root_password_sha2 =272c3ac6b26a795a4244d
root_email = "greg.smith@domain.com"
http_bind_address = 10.10.10.10:9000
http_publish_uri = https://graylog.domain.com:9000/
http_enable_cors = true
http_enable_tls = true
http_tls_cert_file = /etc/ssl/certs/graylog/graylog-certificate.pem
http_tls_key_file = /etc/ssl/certs/graylog/graylog-key.pem
http_tls_key_password = secret_password
elasticsearch_hosts = http://10.10.10.10:9200
rotation_strategy = count
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
allow_highlighting = false
elasticsearch_index_optimization_timeout = 1h
output_batch_size = 5000
output_flush_interval = 1
processbuffer_processors = 7
outputbuffer_processors = 3
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
message_journal_max_size = 12gb
mongodb_uri = mongodb://mongo_user:password@localhost:27017/graylog
transport_email_hostname = localhost
tansport_email_port = 25
transport_email_from_email = root@enseva-labs.net
transport_email_web_interface_url = https://10.10.10.10:9000
http_connect_timeout = 10s
prometheus_exporter_enabled =true
prometheus_exporter_bind_address = 10.10.10.10:9833
ES_config
[root@graylog graylog]# cat /etc/elasticsearch/elasticsearch.yml| egrep -v "^\s*(#|$)"
network.host: 10.10.10.10
http.port: 9200
discovery.type: single-node
bootstrap.memory_lock: true
Hope that helps.
Not sure what else to tell you, but double check you network and firewall configurations.
NOTE: try not to use third-part documentation.
Hello Peter,
I also have Graxlog 4.3.3 up and running, but I’ve had to struggle in the beginning, too. So I kinda understand your frustration.
I’ve just had the same error message in der graylog’s server.log. I did stop the ā€˜elasticsearch.service’ before - so that explained that it couldn’t be connected.
Have you checked whether your elasticsearch.service is actually started? Can you create a telnet connection on localhost 9200?
Thank you for reply but it fails to work for me with latest version
I believe that linux repositories somewhere has something newer then it supposed to be and grayling is not compatible and something fails.
with an older version works fine as soon and grayling is updated to latest version it fails even with old 6.8 elastic search…
so definitely it has to do with linux repository library…
I think grayling should review latest ubuntu procedure installation and update accordingly to get it to work as of July 2022 this instruction fails
I hope someone can figure that instruction out and update here perhaps…
Thanks all
I believe after everything was installed it was working but then in the end elastic search would not connect to port 9200
I dont remember if that was after Linux reboot or after activating final all services
Hello @PeterR
Have you checked your log for Elasticsearch/Graylog? Unfortunately I do not have those issues. I just tested Graylog on Ubuntu it seams to be working fine. If you having connection issues perhaps check the services and/or log files looking or Error’s/Warnings and post them here.
Ok I found a solution
but it required me to change Linux Distro to Rocky Linux 8
I found this tutorial that worked 1 thing I change din instruction was to update Graylog Repository from 4.2 to 4.3 to get latest build
here is url
Rocky Linux 8 Graylog Install
and the line I changed
sudo rpm -Uvh https://packages.graylog2.org/repo/packages/graylog-4.2-repository_latest.rpm
to latest version
sudo rpm -Uvh https://packages.graylog2.org/repo/packages/graylog-4.3-repository_latest.rpm
and that worked for me well and is working as expected
maybe that will help someone
Thanks for updating us,
I have to agree Alma/Rocky Linux are Good. Ubuntu can be a little frustrating. If you could mark this as resolved for future searches that would be Great :+1:
